how can this be, low EGT's???
Old 01-11-2008, 01:25 PM
Floridacracker's Avatar
Question how can this be, low EGT's???
well when i first bought my quad my egt's would go up to about 1,600*
and now i can't get over 1,300* i'm geting fuel i have a 150 airdog
please i need help
thanks tommy
Old 01-11-2008, 01:56 PM
quadman20's Avatar
What you complaining about low egts are a GOOD thing. Unless you want to melt things down. I you have more power with less EGTS thats what you want. So smile and enjoy.
Old 01-11-2008, 02:02 PM
yea but i lost power
Old 01-11-2008, 02:43 PM
DevilzTower's Avatar
ya, but you're turbo will last more than a week now ...
1600* = dead turbo in short order
Old 01-11-2008, 02:46 PM
cquestad's Avatar
Relief valve is gone!!!!!!!!!!!!!!!!!!!!
Old 01-11-2008, 03:21 PM
i never herd of a relief valve? where, what, why.
Old 01-11-2008, 03:36 PM
cquestad's Avatar
The High Pressure Relief Valve is on your common rail (where all of the injector lines connect). The Quad Race pretty much pegs the rail pressure and will eventually wear out the valve...as most presure boxs do when used on their higher settings. Pull out the top banjo bolt...tap the inside of the bolt with a 1/8 npt tap all the way to the head of the bolt (no drilling needed at all) and install a flat head or broached allen head 1/8 npt pipe plug...reinstall the banjo bolt and you will be good to go! A $1 problem...
Or...go buy a new $400 vavlve from Cummins...
Old 01-11-2008, 04:06 PM
JC7588's Avatar
If you have diesel in the valve once you pull the banjo bolt, is that a tell tell sign the valve is going bad?
Old 01-11-2008, 04:09 PM
cquestad's Avatar
No really...but it is not a really good sign either that you have been opening it. I think everytime it blows open...it opens a little easier next time.
Old 01-11-2008, 04:20 PM
JC7588's Avatar
Thats weird seeings how i don't thave a pressure box...unless the juice adds pressure which i thought it didn't.
Old 01-11-2008, 06:00 PM
do u think u could take a pic of it thanks i will be looking into this
Old 01-11-2008, 07:06 PM
i thought all those lines by the rail were under HIGH PRESSURE
how do i take that apart if it is pressured
Old 01-11-2008, 09:24 PM
jballou's Avatar
If you remove the banjo bolt for the rail pressure valve there will be fuel just sitting there with the truck off, due to it also being the return from the injectors. that is where people get confused.
If you do a quick search on testing rail pressure relief valve there will be results on how to test it and how to just " bolt " it as a test.
Don't forget the basics, air and then fuel are needed for a diesel to run well.
Post the symptoms of your problem not just low egt and low power unless that is all. The more of the story the higher chance of getting a good guess.
Good luck!
Totallyrad
07-19-2011 07:41 AM
jmccart
03-18-2007 10:03 PM
jmccart
11-20-2006 06:45 PM
Quick Reply: how can this be, low EGT's???
