can I handle stage 3 injectors?
Old 11-30-2003, 09:03 PM
Evildiesel's Avatar
I was at the track last friday and I ran a dismal 16.71 in the 1/4. With my current mods I was wondering if I could put in some stage 3/100hp injectors without seriously damaging anything. I have a turbo-master that I have yet to install but am hoping that will help with the extra fueling. I dont mind smoke at all (thats why I got the stacks) The only areas that concern me are the fuel pump and the TC. I also just recieved my banjo bolts and fuel line fitting for my guage so I can get a baseline before fooling around with the fuel system. My trans slips a little bit now but Im hoping I can stretch it further before breaking down and getting a Performace version. I think thats everything? Thanks guys.
Old 11-30-2003, 09:32 PM
smittybuilt's Avatar
Re:can I handle stage 3 injectors?
i don't think the tranny would hold up for very long, but i'm sure someone with another auto will chime in.
Old 11-30-2003, 10:05 PM
blackjack's Avatar
Just my 02 but I think that I would put my next $$$ into the tranny It's not going to hold up from everthing I read and hear besides if the tranny is sliping then you are losing power and it is not hooking up. You can't hope to better your times without fixing your weak link and thats you tranny. I preach it constantly when I was building HD's " first put the power you have to the pavement and then you can try to make more"
Old 11-30-2003, 10:24 PM
powerwagon440's Avatar
i had 275's and the drag comp. wire not peirced and thats all my stock tranny wanted!! i would take that advice as said above and safe for the tranny or just do the tranny!!! if u cant put the power to the ground its not very fun!!
Old 12-01-2003, 01:59 AM
AlpineRAM's Avatar
I hope that you can handle them- they come in sixpacks to a total weight of 1.5 pounds ;D
I think your tranny won't be able to handle them. Actually with the stock fluid coupling you will rev to the redline without getting the power to the ground. So it's basically useless to add power now. When I went DTT I felt like- wow where did these extra hundred horses hide?
Just my 2c
AlpineRAM
Old 12-01-2003, 08:12 AM
Evildiesel's Avatar
Did you replace just the TC and Valve body or the entire tranny?
Old 12-01-2003, 10:34 AM
AlpineRAM's Avatar
I've got the update kit. TC, VB, all frictions, billet front piston, updated OD, 4.4 front servo lever, new seals all around.
Personally I wouldn't go for just TC and VB since you can't increase pressure too much with the stock seals in the tranny. Front piston seal likes to blow out and lets you lose pressure.
AlpineRAM
Old 12-01-2003, 10:45 PM
i went with everything! and im all ;D ;D ;D
Old 12-02-2003, 03:19 PM
BigBlue's Avatar
Your tranny can't take it. Mine can't take a Comp in EZ mode.
Old 12-02-2003, 09:44 PM
Sandman's Avatar
My tranny couldn't handle just the EZ either :-[
Old 12-07-2003, 06:45 PM
c-hawk's Avatar
I agree with everyone else so far. Your tranny isn't going to hold a box and 100hp injectors. If you know your in search of more power, the tranny should probably be the next place you spend your money.
Actually, i would rather have my DTT and a stock motor, than lots of power and a trans that couldn't handle it. Now my DTT with a little extra power... ;D
Good luck,
Chris
Old 12-08-2003, 10:20 AM
Olratlr's Avatar
Do your Tranny first then set back and enjoy.
Old 12-08-2003, 10:25 AM
hellotbone's Avatar
Probably not only the manliest of men can handle the power of the almighty stage 3
Old 12-08-2003, 05:27 PM
screwstrokin's Avatar
TRANNY MAN.... im waiting for my parts STILL errrrr. my 3's are sitting here in a box along with all the other goodies....
Old 12-10-2003, 01:08 AM
peanut's Avatar
Maybe some of you can help me with my injector question also. What can my stock tranny and clutch stand up to if i want to step up with new injectors. Whats the largest i could get without worryin bout my tranny and clutch?
Quick Reply: can I handle stage 3 injectors?
