Where can I get a smoke switch?
Old 08-25-2007, 12:19 AM
Madrammin's Avatar
Like the title ask.
My mods are listed below which isnt much but I would love to make a little smoke on the Honda that is tailgating me once and awhile.
Old 08-25-2007, 01:29 AM
wreedCTD's Avatar
Get a SMARTY!
Old 08-25-2007, 10:42 AM
kawiram's Avatar
As far as I know the smoke switch has only been figured out on the Quadzilla products. It's not an actual product you can buy, it's intentionally crossing some wires through a switch to fool your truck.
Old 08-25-2007, 11:58 AM
j
j's Avatar
ok how do i do it? just did the search and got nothing back... anyone have a link?
Old 08-25-2007, 01:02 PM
NoSmokeNoGo's Avatar
https://www.dieseltruckresource.com/...=160765&page=2
I just did this on my 04.5 with a juice. Works
If you want a lot of smoke get a Smarty
Old 08-27-2007, 05:01 PM
gtaj4's Avatar
Quadzilla
I have a Quadzilla Standard Module, does anyone know how to add the switch? I like the way the module works now with very little smoke cause I haul a pretty nice horse trailer and don't want soot on it, but when I'm playing around I'd like to make some smoke. Also, how in the heck do ya add your truck information at the bottom of these posts?
Old 08-27-2007, 05:11 PM
05CTDN8's Avatar
Look on the bar at the top of the page. See where it says USER CP. Go in there and edit your signature.
Old 08-27-2007, 05:17 PM
dodgezilla04's Avatar
[IMG][/IMG]
yes you can add it to your module. way simple.
Old 08-27-2007, 05:53 PM
gtaj4's Avatar
Thanks Shakin Red, I think I got it now. Dodgezilla, It looks like my switch will just short the red wire to the dark blue wire. Is that where it plugs in to the map or the fuel rail?
Old 08-27-2007, 07:06 PM
OldSmokey's Avatar
Map. Just tap the c to the d wire
Old 08-27-2007, 07:44 PM
DTR's 'Go to Guy'
vzdude's Avatar
Ditto on the map sensor, but do yourself a favor and make the connections inside the truck. Lot less wire to rub through or something. Mine ended up only about 10 inches long a piece. Went from switch on the dash to the box on the lower left side of dash. Needs a little more smoke (lasting longer I guess) for me, but hopefully quad will have something up his sleeve in the future?!
Old 08-27-2007, 08:18 PM
gtaj4's Avatar
Okay, I done it. Started the truck up and turned the smoke switch on to see what I was gonna blow up and noticed that it misses like heck at idle. Does that just mean that you need to be pouring the coals to it when you flip the switch on. Probably throws a bunch of extra fuel to it that it can't handle at idle? I connected the switch to the dark blue and the red wire right at the module so the connections would stay dry. Also if all this is right, Does it matter what power level that you have on when ya throw the smoke switch?
Old 08-27-2007, 08:40 PM
DTR's 'Go to Guy'
vzdude's Avatar
Mine seems to like #3 the best, and I make sure the engine is warm when I do it. I have noticed that mine will lope a little at idle if I try it cold, but I don't do it anymore with the commander keeping me from getting to level 3 until the engine is warm.
Old 08-27-2007, 09:10 PM
GrizzlyAdams's Avatar
purchase the hot unlock for your Edge????SMOKIN
Old 08-27-2007, 09:13 PM
gtaj4's Avatar
Thanks vzdude, I can't wait to try this out in the daylight tomorrow!
Quick Reply: Where can I get a smoke switch?
