What can I do to lower egt's
Old 06-28-2009, 10:17 AM
pickupman96's Avatar
I just got back from taking a ride and off a light I got on it and within 400ft with od off she was in high gear and the egts were 1450 and still going. what can I do to lower these. I have to assume that its because of drive pressure. I have read some about porting the wasegate but cant seem to find much info on it. Would that help or it my oly real option twins. Thanks for the help.
Old 06-28-2009, 01:36 PM
HOHN's Avatar
Try some smaller injectors and a bigger turbine side. That PS64/65 is most likely your problem.
I'd be better off going smaller on the compressor and larger on the turbine-- like a 62/71 to replace the 64/65.
JMO
Old 06-28-2009, 05:47 PM
cumminsdriver635's Avatar
I also think a 62/71/14 would be better, but honestly, that isnt all that hot. Mine pegs 1500* by 60mph and holds it until i let out. Im not sure how high it actually gets, but i would imagine 1600-1700*.
Pretty much, these things will make some heat if you have much power. Just have to learn to not worry about it. High EGT's wont hurt anything for a short amount of time. Towing is when you dont want to hold them there.
Eric
Old 06-28-2009, 06:37 PM
Mountaineer's Avatar
Don't give it so much fuel.
Old 06-28-2009, 08:17 PM
Big Blue24's Avatar
Pushing 500+ HP out of an engine designed for 235Hp will create a lot of heat. Once again, 1450 is not that hot. You can't run sustained EGT's that high but a quick blast for 5-10 seconds is nothing.
I've hit 1800+ at the end of the 1/4 mile. Motor seems to run better after runs like that, it burns all the carbon buildup. I'll bet i'd see engine failure if the 1/4 race became a 1/2 mile race though....
Once coolant temp starts to rise, I start to get serious about lifting to cut back fueling.
Totallyrad
07-19-2011 07:41 AM
smog2001
08-10-2007 09:32 AM
Mcmopar
15
09-22-2004 05:49 PM
1320
05-20-2004 04:52 PM
1320
04-23-2004 11:08 PM
Quick Reply: What can I do to lower egt's
