Can 47re torque converter be used on 47rh
Old 10-16-2009, 09:20 PM
fitzydog's Avatar
I have a 94 dually and have access to a 47re billet converter from a 2000 model truck. Will it work. I know the the rh is non lock up and re is lock up? Does it matter? Thanks
Old 10-17-2009, 08:51 AM
dezl-andy's Avatar
no you dont want to do that, even if it would fit.
Old 10-17-2009, 09:12 AM
blackimpala's Avatar
Why?
Why?
Old 10-18-2009, 09:29 AM
fitzydog's Avatar
blackimpala
Thats the same question I have because the 47rh is hydrualic and the RE is electronic, but the torque converter shouldn't matter right? I mean well the RE is lock up but that is electronically controlled maybe that makes the difference. Thanks though
Old 10-18-2009, 11:02 AM
mysterync's Avatar
Yes it will work , lol , i cant belive someone would even say it wouldnt.
For Instance the suncoast converters are as follows
2361819 618 47rh/re single disc for 94-98 trucks
2361819-3D 618 47RH/RE Triple Disc for 94-98 Trucks
The only converters offered by suncoast for 94-98 trucks!
The only changes were in the electronics and tail portion of the trans.
Old 10-18-2009, 01:58 PM
77machomopar's Avatar
So what did they change in 98 that they cant use them till 2002?
Old 10-18-2009, 07:17 PM
dansdodgediesel's Avatar
the 47re is a crock. electronic gov. all it is. Not electronic shift. Work the same way as the 27rh but Gov. press. controlled buy a the computer with three different gov. maps. The transmission works like the older units.
It has just to shift silonieds for the 4th gear and convertor lock up. the rest is all done the old way. The don't work like Ford or Gm. It is way behind time's.
the RH is lock up also, and it is done Electronically same as 4th gear. It just had the Govenor that spine with wieghts on them to control Govenor pressure.
Old 01-03-2019, 11:01 AM
James Howland's Avatar
t
They are both lockup! Lol
one is governed hydrolic and the other is governed electric.
Lockup and od is electric on both lol
Old 01-03-2019, 11:14 AM
Received 2,392 Likes on 1,576 Posts
Originally Posted by James Howland
t
A bit of an old tread to answer, almost 10 years old!, but yes the same converter can be used in a 47 RH and a 47 RE.
Metal Twister
07-26-2014 12:17 PM
joem
15
06-05-2012 12:12 AM
arren333
12-08-2011 07:38 PM
wvopowered
01-14-2011 08:04 PM
Need95-00CTD
08-27-2007 02:10 PM
Quick Reply: Can 47re torque converter be used on 47rh
