cam shaft sensor location
Old 08-01-2010, 04:27 PM
Hothead2500's Avatar
My truck died on me going down the highway today and the code i pulled was p0336, cam shaft sensor. can anyone tell me where it is located? please help!!!
Old 08-01-2010, 09:15 PM
JD730's Avatar
Underneath the injection pump, real bugger to get to when the pump is on. Same place the TDC pin is on a mechanical engine.
Old 08-01-2010, 09:39 PM
Junk Man's Avatar
I changed my cam sensor with the VP. Get air horn plumbing & accelerator linkage out of the way & you can change it. I think it took a torx bit but look it up in the FSM. pdftown for the 01 fsm if you don't have it.
Det 1
17
12-22-2009 08:32 AM
DanTaylor
04-23-2007 08:27 PM
59FORD
04-07-2006 12:28 AM
deezulsmoke
09-14-2005 10:41 AM
gunracer1
03-09-2005 08:29 PM
Quick Reply: cam shaft sensor location
