Cam/Injector input/help
Old 02-21-2008, 11:30 AM
Troutstrannysvc's Avatar
I recently got my head resurfaced, o-ringed, #60 valve springs and ARP 12MMs.
I plan on running a SPS62/12 turbo (or equivalent).
I recently got my injectors pop tested when the head was getting worked and they failed.
I have read on numerous sites about the spray pattern on the 370s.
So what injectors are JUST RIGHT for the stock piston bowl and throw down a lot of fuel?
I plan on running the Helix II cam and next winter I plan on doing a rebuild on the engine and running Mahle pistons but we'll talk about that when the time comes.
So basically I am looking at what Turbo/Injector/Cam combo will work the best?
Helix II; Bolt on gear; $750
SPS 62: $1395
Injectors??
Any input would be appreciated
Old 02-21-2008, 04:06 PM
logskidder's Avatar
SPS 62: $1395
Injectors??
I would go with DDP stage 3's, take a diegrinder to the head while its off and instead of a cam I would use that money to get the pump benched. Who in Pa oringed your head ....I need to get one done.
Old 02-21-2008, 04:30 PM
dzlfarmboy's Avatar
At set of DDp 3' would be a nice setup with a 62 could possible go with 4's depends on what your doing with the truck. Where in Pa are you guys at I have my engine machining done up in Carlisle pa.
Brett
Old 02-21-2008, 04:39 PM
logskidder's Avatar
Brett
Im on the other side........50mi east of Pittsburgh
Old 02-21-2008, 05:43 PM
97' CTD's Avatar
DDP 4's
Brandon
Old 02-22-2008, 12:42 AM
Bjans's Avatar
try some dragon flys from ii/ They are pretty sweet and they may make you a package deal with the turbo
etn550
04-01-2010 12:12 PM
Pleyster
27
08-04-2009 12:37 AM
AH64ID
01-18-2009 04:59 PM
RUSSDWOLF
02-07-2008 10:35 PM
Joe Diesel
11-12-2007 08:59 AM
Quick Reply: Cam/Injector input/help
