Ca. smog
Old 10-31-2011, 05:07 PM
klcammie's Avatar
Ca. smog
Just tried to get my 01 smoged Sat. was going along fine right up to the last thing, it's called a MIL check. Thats a malfunction indicator light. Mine failed because 4 days before the smog I had to change the battries. When both batts are disconnected you clear the computer of all codes. Since I had only driven about 20 miles there was not enough data in memory. So heads up don't clear computer memory before smog. Now I got to go back after driving 75-100 miles and pay another 28.00.
Old 10-31-2011, 08:23 PM
rebal's Avatar
find a better shop I set mine back to stock cleared the codes and drove it 1 mile to the smog shop ,it passed fine ,Another shop didnt want to smog it because the missing puke bottle and BHAF, go to a good shop and talk to the tech first.
Old 11-02-2011, 04:35 PM
klcammie's Avatar
I thought about another shop, but this guy didn't care about missing puke bottle or BHAF. It was the computer at the state that wanted more history. So will be going back Sat. will post after.
Old 11-02-2011, 07:57 PM
bob4x4's Avatar
That is not the same as a batt disconnect...............
With the factory scanner there are 2 options,clear dtc's or clear and batt disconnect.Just clearing dtc's doesn't dump the monitors,neither does the Smarty
Old 11-03-2011, 09:43 PM
KATOOM's Avatar
Its amazing what I hear some of these smog shops come up with. The only way I've ever heard it is there can be no codes in the system. Amongst all the mechanical requirements. I've advised this many times but never known if it helped, call the closest high performance diesel shop located by you and ask them who to take the truck to. You'd think they would know more than anyone.
javabeanjava
06-07-2004 05:09 PM
Cappy
05-26-2004 05:05 PM
Cowhand
04-17-2004 07:26 AM
Tackdriver
11-26-2003 07:19 PM
Quick Reply: Ca. smog
