A/C Vents??
Old 04-15-2010, 09:22 PM
R Walter's Avatar
A/C Vents??
Went to switch on my AC in truck no 1 in my signature today, and was not able to get any cold air through the in-dash vents. It seemed to be making cold air fine because I could feel nice cold air coming through the two floor vents normally used for heat. Every time I switched to the in-dash vents... nothing.
Any ideas what's up?
Old 04-15-2010, 10:21 PM
torquefan's Avatar
It's possible the vacuum actuator for one of the mode doors in your HVAC system has stopped working. You can leak test them with a vacuum pump, and sometimes a visual inspection is all they need. I've seen a few with the diaphragm all swelled up from a bit of oil intrusion over the years.
I'm guessing it isn't a vacuum supply problem, because with no vacuum the system should default to defrost. I've never seen a broken door on a 2nd gen, so unless a foreign object has found its way into the system and jammed a door open, (fairly common-pens down the defrost vents) my bet is an actuator.
hognutz
09-15-2009 06:53 PM
Dargo
05-14-2004 12:03 PM
Geets
03-16-2004 11:57 AM
CumminAtYa
09-27-2003 02:58 PM
Quick Reply: A/C Vents??
