A/C problems
Old Jun 21, 2010 | 06:21 PM
cumalong's Avatar
A/C problems
My 02 Air Conditioning unit hardly works. Every now and then it cools for a few minutes. It works less when it is hot. Any notorious things to look for? Could the compessor be working very intermintently? Any ideas? Thanks
Old Jun 23, 2010 | 11:00 AM
supr's Avatar
I have gone through 4 evaporators and 1 high pressure switch. The evaporators seem to made of a weak aluminum, I think. Not sure if there are any replacements that are better.
If you are not good with AC, I would suggest finding a good AC shop you trust. You live in the South, and i think AC is a necessity here, the summers are so freaking hot and long.
You may try adding some more 134A to see if that helps short term. You can get a chaging hose at most auto shops. The Low pressure side is up by the air cleaners, near the firewall. I take my Air cleaner top off for easier access.
It may take up o 1.5 cans, id it is leaking bad.
Old Jun 24, 2010 | 08:33 PM
trust's Avatar
yep, if the compressor is running intermittently or very seldom, it may be low on charge which is easy to do, just pick up the coolant and a hose and follow the instructions. You should get a can of dye and find the leak, mine has been a pita with one thing after another leaking and needing to be replaced, it works now except stopped in traffic and even at speed it doesn't get below about 45-50 F out of the vent.
I'd pick up a hose and a couple cans of coolant and do a quick recharge for $15 or 20, if that fixes it then fill er up, if not then find a shop
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
