A/C Problems
Old 07-01-2008, 03:01 AM
EverydayDiesel's Avatar
A/C Problems
I recently replaced my compressor, condenser, drier, and liquid line(with orface tube) I put the proper 2 1/2 cants in the system with the proper oil amounts.
The A/C blew ICE cold for a month or so, but now the vents only blow about 75-80 degrees (use to be 45)
The liquid line is very cold but the drier is very hot.
The compressor is coming on.
What would cause my liquid line (coming from the condenser to the firewall) to be cold but my drier to be hot? The drier is suppose to be cold with lots of condensation.
Old 07-01-2008, 07:36 AM
pull-do's Avatar
Follow your warm line to where it turns cold, there is where you should find a restriction in the line, -------AC temps works on pressure drops, that's how it cools at the orifice tube, pressure drop = cold freon bleeding into your accumalator-------- this would be my guess with out looking at the system.
Old 07-01-2008, 06:05 PM
when I hook the gauges up both sides read about 100
With the a/c going the cool side bounces between 20 and 60 while the hot side stays from 130-170
outside temp was 94 degrees
Old 07-02-2008, 07:24 AM
patdaly's Avatar
Blend door?
Old 07-02-2008, 08:20 AM
pull-do's Avatar
What do you mean by bouncing, is it "cycling" that far, or is it just fluctuating on it's own, if it's "cycling" that far, I would suspect the low pressure cycling switch, if it's doing it on it's own, the high side pressures seem low to me.
Old 07-02-2008, 12:10 PM
the pressure changes as the compressor kicks on and off.
the compressor is turning off and on every 6 seconds or so
I think i have a leak.
Old 07-02-2008, 12:34 PM
PaulDaisy's Avatar
I too think that you are losing charge. They now sell refrigerant with a UV dye added to help finding leaks.
Old 07-02-2008, 03:27 PM
pull-do's Avatar
I think you nailed it their, be nice to know where the leak is, hopefully not the evap coil
DJ Turbo.
10-13-2011 09:11 PM
staken
03-05-2008 07:41 PM
95 Dodge
07-02-2006 03:28 PM
olgraybeard
03-24-2003 06:32 AM
Dwight
03-18-2003 08:14 PM
Quick Reply: A/C Problems
