A/C problems
Old Dec 13, 2006 | 01:16 AM
Ol'Red's Avatar
Angry A/C problems
my a/c and heater both blow through the top of my dash no matter what setting i have it on, the temp **** and blower speed still work but the other control doesn't. what's wrong?
Old Dec 13, 2006 | 02:41 AM
Scramblinman's Avatar
Probably a vacuum leak. First place to check is the vacuum line that runs along the firewall right above the exhaust.
Old Dec 13, 2006 | 08:01 AM
jrs_dodge_diesel's Avatar
Yes, you most likely have a loss of vacuum. The way it was designed, if you ever lost vacuum which controls the A/C and heater vents, you would never lose defrost. Start at the source (vacuum pump) and work your way back towards the A/C system. I found once that my A/C came out of the defroster vents, this was a result of me doing maintenance in the engine compartment and knocking the vacuum hose off of the vacuum pump.
Old Dec 13, 2006 | 09:58 AM
Luckycharm1's Avatar
where is the vacuum pump located? where is the best place to get replacement (better than oem) lines and elbows to use?
Old Dec 13, 2006 | 11:52 AM
The vacuum pump is just forward of the power steering pump. As for replacement lines and elbows, I would personally just use whatever the local NAPA or auto parts store sells. They all seem to be about the same.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
