A/c Problems
Old 05-10-2006, 07:49 PM
Chad Buell's Avatar
Question A/c Problems
The clutch on my a/c compressor keeps engaging and disengaging
even with the a/c switch off, and with the a/c on the air
isnt cold. Any ideas ? Could it be the a/c relay ?
Old 05-10-2006, 08:42 PM
edwinsmith's Avatar
Received 1,038 Likes on 763 Posts
No, it's the low pressure switch on the low side. When your compressor kicks in it lowers the pressure on the low side and the switch opens then when the pressure equalizes the switch turns the compressor back on.
The cause is you need to add some refrigerant to the system. It's low.
Edwin
Old 05-10-2006, 09:35 PM
sled4fun's Avatar
Have the system checked by an a/c shop.
Yes it could be low (this means you have a leak that needs to be fixed) It could also be a faulty low pressure switch, faulty thermostatic sensor, on/off switch etc. etc etc.
Old 05-11-2006, 01:19 AM
kerryneb's Avatar
A/C is on when defrost is on. air conditioned air is dryer and therefore a/c is used to help defrost windows.
Old 05-11-2006, 05:40 AM
sadlerb_98's Avatar
Mine did the same thing. I took the truck to the dealer on Monday. It was 2 units low on Refrigerant. They couldn't identify a leak yet but there must be a good one.
Bob
DJ Turbo.
10-13-2011 09:11 PM
staken
03-05-2008 07:41 PM
95 Dodge
07-02-2006 03:28 PM
olgraybeard
03-24-2003 06:32 AM
Dwight
03-18-2003 08:14 PM
Quick Reply: A/c Problems
