A/C Output Fluctuates
Old May 17, 2007 | 12:46 PM
megamac's Avatar
Here is the deal. My A/C usually works fine, then out of the blue, the flow of air out of the vents will slow down to a light breeze, even thought the unit is on Max and the fan is on high. You can hear the fan running fast as it should on high max, but barely any air comes out of the vents.
Then after a period of time (1 to 2 hours) it will go back to running as normal.
This has been ongoing now for a couple years and I am now living in Arizona and so I need to fix it. Any suggestions!
Thanks,
Old May 19, 2007 | 09:41 AM
ironman's Avatar
Insure you are on recirc, and then try different positions for the dampers and insure they are redirecting the air flow. If not then consider a vacuum leak.
Old Jun 7, 2007 | 11:45 PM
megamac's Avatar
Seems like I found the problem. I added R134 and the problem went away.
RonA
Dec 4, 2006 09:50 AM
TheFog
Apr 11, 2006 07:36 AM
Deer716
Oct 5, 2004 09:29 PM
Bill Tomlinson
Sep 22, 2004 04:21 PM
Gabe
May 4, 2004 11:44 PM
