A/C fan motor not working right
Old 06-20-2009, 12:15 AM
Jmac's Avatar
Hey all, yet another installment to my A/C saga. The A/C will not turn on or blow air until the **** is all the way over to full speed on the fan motor control. I'm told it does not work on a step down relay, but a resistor somewhere in the heart of the A/C system. What about a loose wire? Thanks Jamie
Old 06-20-2009, 07:59 AM
MikeyB's Avatar
First thing to check is the electrical connections behind the HVAC control head and at the blower motor. If the connections look good then it's either one.
MikeyB
Old 06-20-2009, 10:08 AM
Spooler's Avatar
Connections to check. Yes, at the steering colmn which connects to the ignition switch. Since yours works on high you do have a set of dropping resisters and that is what sounds like is wrong with it.
Old 06-20-2009, 06:18 PM
Jmac's Avatar
How do I get inside the steering column? Where are the dropping resisters located??
thank ya,
Jamie
Old 06-20-2009, 10:20 PM
Spooler's Avatar
Steering colmn, screws from underneath. Fan resistor pack is in the vent after the fan the last I remember. Can't miss it.
Old 06-21-2009, 03:19 AM
TexasCTD's Avatar
My problem may have been completely unrelated to yours....but thought I would share my experience here.
My a/c blower was running slower and slower, particularlly on the first 3 speeds. High would blow decent for a while then it would even start running slower. Sometime, I would have to reach under the pass. dash and "tap" it with my metal flashlight to get it to work.
Well I finally just bought another blower from the dealer and replaced it. Now it works great!!! I actually have to turn the blower speed down now while driving in the Texas 100 degree heat in my black truck after it cools a bit. I used to cuss my A/C but im very pleased so far this summer!
Sleigher
05-04-2017 02:12 PM
Michigan Ram
08-24-2011 11:25 PM
big jimmy
07-07-2006 01:33 PM
halerazor
01-03-2005 10:51 PM
blackjack
11-08-2004 03:04 PM
Quick Reply: A/C fan motor not working right
