A/C compressor cycling ?
Old 04-22-2006, 04:53 PM
SilverRam01's Avatar
I've noticed that my AC compressor is cycling even when I dont have the AC or Defrost selected. Anybody know why this is ?
Old 04-22-2006, 09:58 PM
Charlie8301's Avatar
I've wondered the same thing
BTTT
Randy
Old 04-23-2006, 03:29 AM
Jim Dynomite's Avatar
Maybe that slight hesitation you're talking about in your signature is the A/C compressor kicking on and off.
Now, why the A/C compressor solenoid is firing is beyond me. Maybe someone with a wiring schematic will chime in.
..........................Jim
Old 04-23-2006, 09:05 AM
J BODY's Avatar
what position do you have your mode switch in? face and floor are the only two positions where it won't run.
Old 04-23-2006, 10:28 AM
Mine will do it even in the off position
Randy
Old 04-23-2006, 03:57 PM
dansdodgediesel's Avatar
Your low on 134a.
Dan
Old 04-23-2006, 09:38 PM
Randy
Yeah, mines the same way. Cycles in all positions, even with all air control switches off.
I did try to run the A/C the other day, and noticed that it wasnt blowing cold. This would makes sense if I'm low on coolant. My auto repair shop recharged my system last year....so I must have a pretty good leak. Seems like there are quite a few on this board that have AC problems, must be common in these trucks? What is the most common failure....condensor leak?
Also, I really dont think the idle hesitation has anything to do with the AC compressor. Guess anything is possible however.
Old 04-24-2006, 11:11 PM
J BODY's Avatar
I know in the humid northern parts techs have seen evap leaks due to "krap" building up in the hvac box (old leaves, twigs, pine needles) but down here I would say I'm almost at 8 out of 10 complaints of "I had my a/c serviced and it's not working again after six months to a year...." ends up being the compressor. Leaks as a vapor out of the front seal. I've pumped dye into a few 2 to 3 times and nothing ever showed up until I installed a new compressor and disassembled the old one to find slight traces of dye at the front seal. I put a compressor on my 01 last year. So far, so good. On the subject of the compressor running with the controls "off" is not right. Low charge shouldn't have a thing to do with it either. Someone needs to check the inputs to the compressor as to why it's engaging.
Old 04-26-2006, 10:42 PM
hink's Avatar
yeah, what dan said. it needs recharged. just had mine fixed last week. it was doin the same thing.
Old 05-01-2006, 08:57 PM
GBRACER's Avatar
The evaporators in the dash are prone to failure due to debris and water collecting on them I do AC work on the side and changed a few of them.
Big job whole dash comes out and heater box. 8hrs
Old 05-02-2006, 11:41 AM
VADSLRAM's Avatar
I paid $800 to have mine replaced
They said it was a known issue of condesation not draining well and rotting the outside forward corner of the evap coils.
Old 05-02-2006, 10:09 PM
J BODY's Avatar
...however if you move to the desert like I did, you won't see that problem.
Old 05-07-2006, 08:07 PM
sadlerb_98's Avatar
SilverRam01,
Did you get it fixed?
Bob
modiesel
08-10-2010 07:46 AM
CTD2001
04-16-2010 01:03 PM
Coaldigger
09-24-2008 03:05 PM
MRuskow
10-24-2007 11:31 AM
kawi600
06-04-2006 03:13 PM
Quick Reply: A/C compressor cycling ?
