A/C Compressor clutch replacement procedure
Old 02-13-2009, 07:34 PM
1970dodge's Avatar
Can the clutch be replaced on vehicle and what tools are needed?
Thanks.
Old 02-13-2009, 07:43 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Sure, but it depends on which vehicle you have.
Old 02-13-2009, 08:03 PM
1970dodge's Avatar
Sorry, 1996 3500
Old 02-13-2009, 08:04 PM
roughstock's Avatar
What vehicle?
If you are talking about a CTD, yes, kinda, you have to take out the bolts and tilt the compressor down, so you can get puller in there to pull the pulley.
Need special wrench to hold pulley/clutch face still while removing nut in center, i think its called a spanner wrench.
becareful not to loose any washers(shims) when pulling assembly off shaft. Shims are behind the assembly.
Old 02-13-2009, 08:09 PM
1970dodge's Avatar
Yes, it is CTD. Again sorry for the lack of info. Thanks for the help. Is spanner wrench fairly accesible ( where do you find one)
Old 02-13-2009, 08:38 PM
roughstock's Avatar
Try a Napa.
Where did you get the clutch assembly?
bradler
02-19-2009 10:53 PM
dixiedog
07-29-2007 07:03 PM
docram
11-07-2006 11:16 PM
Tommy93w350
07-07-2006 01:35 PM
Buffalo
05-25-2006 11:33 PM
Quick Reply: A/C Compressor clutch replacement procedure
