C.B mounting questions.
Old 05-02-2004, 09:41 PM
tool's Avatar
Hey all, I just bought a Dale Earnhardt edition Cobra 29 C.B radio at a T.A truck stop in P.A the other day, now I gotta get the thing mounted in the Dodge.
Not many great mounting places with a 4x4 5 spd are there??
Anyone have any good ideas?? pics would be super.
I'm hoping to go with a dual 3' fibreglass antennae setup.
(mounted on the box behind the cab) anyone know of good brackets/mounting setup for this as well?? Would like to make it look good and do as little destruction to the box as possible.
Old 05-02-2004, 10:07 PM
crobtex's Avatar
I don't have any pics, but I mounted mine to the plastic cowling below the 4wd lever. Drilled two small holes and mounted the bracket so the bottom (rear) of the cb would be right at the floor. It's out of the way and is easy to get the power and antenna to it.
The brackets sold with the Fire Stick twins have brackets that will mount to the tool box with minimal damage. Most truck stops carry the twins for around $37.
Old 05-02-2004, 10:21 PM
dieselcrazy's Avatar
i bought the brolin mount ... it works great in my 5 spd. puts the cb between the seat and the shifter. i forget the site but hopefully some1 else will chime in.
Old 05-03-2004, 12:21 AM
BigBlue's Avatar
I mounted mine above the e-brake handle. If your not careful, you'll hit your knee. But I like it right there. I've got the 3' firesticks mounted on opposite sides of the bed. I get great reception. I just bought the matching firestick mounts.
Old 05-03-2004, 05:46 AM
Administrator / Scooter Bum
Shovelhead's Avatar
www.sourceautomotive.biz
carries the Wundermount. (used to be called the Brolin Mount)
http://www.protintnw.com/sa_dodge-acc.htm
Scroll down to see pics.
Old 05-03-2004, 09:41 AM
surfram's Avatar
Firestick makes stake hole mounts that mount up without any drilling. I have the extended version that fits underneath my cap with no interference. Check out firestick.com
Old 05-03-2004, 06:14 PM
farmer dave's Avatar
I mounted mine just below the ash try. Out of the way, yet close at hand when needed. Nice to have when you are driving on the freeway, truckers are always talking and they let you know where the cops are.
Old 05-03-2004, 06:18 PM
perk's Avatar
I agree on not having many good places to mount the CB. I want to mount mine to the ceiling, but I am a little unsure if it is possible. If anyone has done it, what does it take? any pics?
Old 05-03-2004, 09:58 PM
mic646's Avatar
I like the BGBW Wunder mount. I wonder if it would work with my smoothie.
Old 05-05-2004, 09:04 AM
perk's Avatar
Where did you guys pull power for the CB?
Old 05-05-2004, 11:00 AM
Shovelhead's Avatar
From my Painless-Wiring Add-on fuse block.
Old 05-07-2004, 11:43 PM
tool's Avatar
o.k, how about antennas?? What have you all done with antenna mounting? (whips on the box with the least destruction)
65sixbanger
10-26-2010 10:19 PM
bigfoot
05-26-2009 02:12 PM
justagoodolboy
05-05-2008 03:35 PM
atc250r
03-22-2003 12:27 PM
j
15
11-21-2002 09:56 PM
Quick Reply: C.B mounting questions.
