"C" in 8th position of VIN on 2002 6-speed HO?
Old 03-05-2010, 08:29 PM
royta's Avatar
According to http://www.dodgeram.org, the only two characters you should find in the 8th position of the VIN on an 01 or 02 should be a "6", for an SO engine, or a "7" for an HO engine. I have the build sheet for a 2002 HO 6-speed that contains a "C" in the 8th position of the VIN. Why, and what does it mean?
Old 03-06-2010, 09:39 PM
royta's Avatar
Well, I picked up an 02 today and it has the factory exhaust. It does have what appears to be a catalyctic converter before the muffler. Although, if it is a catalyctic converter, it is much smaller than the one that came on my old 97.
Do the trucks with the "6" or "7" in the 8th position also have a catalyctic converter?
ETA - The "Options Report" that I had printed up at the Dodge dealership shows "NAA", which is "Federal Emissions".
Old 03-07-2010, 02:28 AM
Tate's Avatar
Those are resonators, no cats on 24v's.
Old 03-07-2010, 05:49 AM
royta's Avatar
Thanks. The resonator is completely hollow, with no exhaust flow restriction, correct?
Old 03-08-2010, 06:56 PM
SIXSLUG's Avatar
I beleive they are. The biggest restriction I recall was at the turn up over the rear axle on mine. It got down to about 1 3/4".
My 8th digit in my vin is a "7".
Old 03-09-2010, 09:59 PM
dweller's Avatar
My '02 has a "C" in the eighth position of the VIN.
Old 03-11-2010, 04:42 PM
SIXSLUG's Avatar
Maybe that changed for the 02 model year. When I was searching for trucks I only looked at one 2002 and it was a 6-speed so I knew it was an HO.
Old 03-14-2010, 07:58 PM
kicker210's Avatar
mine also has the vin code "C", and i did work at an auto parts store and in the computer it listed the models "6" "7" and "C". and for instance i needed the sensor for the 4wd light on the dash and i ordered the one for the model 7 not knowing the difference and when it arrived it was a fatter sensor than whats on the "C" modeled trucks so there is something different in them but i also dont know what the official difference is
roughstock
11-02-2013 01:48 PM
yarddog
03-11-2011 12:42 PM
Bowser50
07-26-2009 07:22 AM
2nGlenn
04-10-2009 01:33 PM
Locomotion
03-12-2005 09:01 PM
Quick Reply: "C" in 8th position of VIN on 2002 6-speed HO?
