Bypassing a Electronic Wastgate
Old 01-25-2008, 03:41 PM
cincydiesel's Avatar
Is there a way to get around the Electronic wastegate on an 05? I trying to trouble shoot a problem with low boost (25psi max)
Old 01-25-2008, 03:43 PM
OldSmokey's Avatar
Yep, you need some type of boost fooler that hooks to the map sensor. Then clamp off the wastegate hose on the turbo with vise-grips or something similar.
Old 01-25-2008, 03:54 PM
I've got the Edge J/A and the smoke switch. Whats the long term affects of clamping this off.
Old 01-25-2008, 04:31 PM
AH64ID's Avatar
There is no need to clamp anything off on the 04.5 plus... .
The cheapest will be the quad boost fooler...
How are you reading boost? It may be your gauge, my first pricol would only read 25-27.. my new one read 32 before I did the Jr, now it reads 34-35.
I think the Edge J/A boost fools thou....
Old 01-25-2008, 06:04 PM
I clamped the rubber hose leading to the wastegate and I'm building boost with no problem. Thanks a million
Old 01-26-2008, 10:49 PM
AH64ID's Avatar
That would tell me you have something wrong, as that doesn't need to be done. I would guess your masking a problem.
Old 01-27-2008, 02:12 PM
wardy70's Avatar
Cincy that is what was wrong with my truck also after all that there was a wastegate problem.
Bruce M
12-17-2013 02:59 PM
sinawalli
05-27-2008 10:03 PM
Bham Ram
03-29-2007 05:00 PM
robert78.5
12-26-2006 10:52 PM
adidasman23
12-22-2006 02:43 PM
Quick Reply: Bypassing a Electronic Wastgate
