Buzzing wierd noise, tranny?
Old 04-06-2007, 11:25 AM
Silverfox99's Avatar
Lately my tranny has been acting up fluid level is good but on corners here and there it wont catch then it grabs it also does that every morning when i leave my house. It seem like it always takes off in 2nd gear , if you floor it it will hunt back and forth through gears sometimes. Now i get this buzzing noise that starts around 1700 r's when im on it my buddy thinks its the tranny but im not sure....but it doesnt do it in neutral what could this be? and what in the tranny would buz like this
vp44
lift pump
starter
batteries
rusting out bad
possible tranny im pumped up
Old 04-06-2007, 12:53 PM
bill50cal's Avatar
drop the pan and have a look. a pluged filter can cause pump noise. more noticeble at higher line pressure.
bill
Old 04-06-2007, 01:33 PM
Ill probly do that tomorow, the fluid in the pan and the filter were changed like 6 month ago. I spose ill drop it check that out maybe tighten the bands then see how it operates and if it still buzzes.
Any other things to try or thoughts let me know!!!
Silverfox99
04-14-2007 01:54 PM
ratat98
03-06-2007 01:11 AM
turbotom
10-09-2006 10:25 PM
BLKHO600
03-21-2005 11:28 AM
bronco351
08-31-2004 01:19 PM
Quick Reply: Buzzing wierd noise, tranny?
