Bump Steer
Old 11-07-2006, 07:06 PM
jkap's Avatar
Bump Steer
I have read a few steering post that talk about "Bump Steer". What actually is this, and is it also related to the track bar?
Old 11-07-2006, 07:24 PM
Racer9's Avatar
AHH Yes, now we're into racing terms. Bump steer is the change in steering specs due to a change in chassis ride height. this can occur from going over a bump, the front end lift from accelerating, the front end dive from braking, and the sway from turning. If you set your steering specs, then jack up the truck by the frame, the specs will change. Thats bump steer.
The track bar centers the front axle, so a change in ride height, ie; a lift kit, will change the angle of the track bar, and therefore the location of the front axle.
This will affect the toe-in and steering wheel centering also, although possibly not enough to notice.
Old 11-09-2006, 06:29 PM
Mainemike100's Avatar
Adjustable Track Bars
Adjustable Track Bars are available from several suppliers to allow for centering the front suspension after a lift or lowering kit. If you're running stock ride height it shouldn't be an issue.
Old 11-09-2006, 06:36 PM
Captain's Avatar
on both of my trucks with 6" lifts we have some minor bump steer with the 03 trac bar conversion and adjustable trac bar. Its not very noticebale though and you have to hit a good size bump and speed for it to happen. with the 2" lift and 03 conversin and stock 03 trac bar i never had bump steer.
PA90Ranger
12-28-2010 04:36 PM
3500CTD
08-12-2010 01:55 PM
afoulk
01-10-2008 12:24 AM
2006 MEGACAB
34
07-19-2007 09:37 PM
2006 MEGACAB
06-29-2007 04:54 AM
Quick Reply: Bump Steer
