bullydog or smarty
Old 06-14-2007, 06:05 PM
CottonRam08's Avatar
bullydog or smarty
Im new to the common rail motors and need some help with programers. I like the new bd pmt because of the gauges and defueling but is it worth the money. I have a stock 07 auto with air and exhuast upgrades.thanks
Old 06-14-2007, 07:39 PM
white06's Avatar
it depends do you like smoke ?
Old 06-14-2007, 07:48 PM
duranator06's Avatar
I have the bully dog triple dog and I love it. I would recomend guages either way you go and if you like smoke, it smokes a ton on crazy larry.
Old 06-14-2007, 07:50 PM
Pooter's Avatar
I still cant decide either
Its between those two though, because I need the speedo correction(for the shift points)
Id also like to be able to turn on high idle as well.
Triple Dog is cheaper, but Smarty is more adjustable/tuneable, many different settings.
Old 06-14-2007, 07:51 PM
Luvnacumns's Avatar
Smarty!!!!
Old 06-14-2007, 08:41 PM
I like smoke
Old 06-14-2007, 08:44 PM
StrokeThisCTD's Avatar
i love my bullydog
Old 06-14-2007, 09:39 PM
rynemurch's Avatar
SMARTY!!!!!
Old 06-14-2007, 09:40 PM
dodgezilla04's Avatar
SMARTYcan you hear me now?
Old 06-14-2007, 09:45 PM
MoparRiggan's Avatar
Smarty !! all the way !! You can control smoke with smarty by using the stock torque management software. Smarty is just so user friendly according to what you have done to your truck. from Stock to wild mods , Smarty definately covers them all....
Old 06-14-2007, 09:50 PM
dodgeboy59td's Avatar
Bullydog!!!!!!!!!!!! you can change stages on the fly!
Old 06-14-2007, 09:53 PM
Ok with the bullydog you can control the smoke by not enabling the "low end power option" which is a decrease in torque management.
Old 06-14-2007, 09:58 PM
Luken's Avatar
Bully Dog. I've tried both...
Being able to adjust on the fly is a plus for the bully dog as well...
Old 06-14-2007, 10:24 PM
MegaBOMB's Avatar
The Triple Dog doesn't do speedo recalibration. The only programmers that will do that for an '05 are the SmartyCR and FlashPaq. However, the dealer should be able to adjust the tire size on an '05 without issue.
Good Luck!
Old 06-14-2007, 10:28 PM
Bob Wagner's Avatar
G said you were smiling LMFAO!
Quick Reply: bullydog or smarty
