built trans what does your trans temp gauge read
Old 02-17-2010, 06:08 PM
1985cucv's Avatar
for those of you with built trans what does your trans temp gauge read when your getting on it and towing with it? thanks
Old 02-17-2010, 06:18 PM
Dave04600's Avatar
It is cold here in ct and my gauges stays at 100-110 unloaded 150 towing a trailer. It is about 30 degrees higher in the summer on average
Old 02-17-2010, 07:07 PM
bigjohn04's Avatar
165 is the highest I've seen towing in town usually 135 on the highway
Old 02-17-2010, 07:57 PM
Neight's Avatar
Remember I'm in Az, but mine sits right around 180 running around town and I haven't towed with the built trans yet.
Old 02-18-2010, 02:03 PM
namotuman's Avatar
i'm in california here and i see 160-175 around town with avg. 70 temps. will run closer to 160 when fully warm and if the outside temps are cold in the a.m.
towing is a different story...i go to the high dez and the mountains (sierras). towing my rig anywhere from 7.5k to 10k weight, it will run 190 on flat terrain to moderate grades. going on steeper grades, i.e. 10% and such it will go into the 210-220 range. last summer i towed up to 9260ft and the temp spiked up to 250. that was before i got my smarty jr. i have not seen any temps over 210 since i've loaded the tow program and no egt's over 1150 pulling fully loaded up 8-10% grades in full lock up @ 60mph....
2003CDRW
10-16-2014 06:52 AM
jesussaves
12-30-2009 06:35 PM
svtrich
12-03-2006 08:26 PM
manganos
11-22-2005 12:37 AM
stevenknapp
27
07-10-2004 01:11 AM
Quick Reply: built trans what does your trans temp gauge read
