Bug screen
Old Apr 19, 2004 | 06:47 PM
jnck's Avatar
Lightbulb Bug screen
I gave up tryin to find a bug screeen for the front.
So I built it myself.
31 1/2" wide by 20" tall. Covers full width and about 85% height
Went to Lowes and got everything to make a normal screen
window and used existing mounts bolts with nylon spacers.
I have learned alot from everyone here and thought I would share what little I could
Old Apr 19, 2004 | 07:22 PM
RHC's Avatar
RHC
Thanks for the info on the bug screen. Thinking about doing me one. Have you had a chance to pull a load in hot weather with the
bug screen installed? Just wondering if the screen would reduce the cooling efficiently any?
Old Apr 19, 2004 | 07:32 PM
jnck's Avatar
Sorry I am mostly empty.
By the volume of "critters" I have brushed off in 3 weeks I think the various radiators not having bugs crammed in them will off set the screen.
I hope that makes sense
Old Apr 19, 2004 | 08:07 PM
guzzirider's Avatar
Looks like you got longer bolts with spacers is that correct?
Old Apr 19, 2004 | 08:18 PM
jnck's Avatar
1/2 " spacers for the bottom
1" for the top
1" bolts for the bottom
and 2" for the top. Cut about 1/4" off the 2" bolts. they are almost too long
Used aluminum wire. Thought it might hold up to rocks better.
Old Apr 19, 2004 | 08:22 PM
AaronT's Avatar
I use fibreglass screen, and velcro to hang it from the top frame with it resting against the coolers. Stays cool this way (without a buffer zone between screen and coolers) and is easy to pull out and wash off. Cheap and lazy but it works for me.
Old Apr 19, 2004 | 11:40 PM
SuperGewl's Avatar
My setup is simular and it does not effect the air flow, unless it's full of bugs
Old Apr 19, 2004 | 11:43 PM
Truckjerk's Avatar
If i recall KilbyEnterprises offers one, aswell as Geno's Garage. One member also gave the demensions of the one he did...with quite a few pictures.
http://community.webshots.com/album/101009905zukxrI
Nickleinonen is the name that gets the much due credit!
Old Apr 21, 2004 | 10:05 AM
RJS's Avatar
RJS
Here's a quickie, cheap way to install a screen. (I wish I would have bought black screen.) Just place the screen under the hose that crosses the radiator and press the hose back into the clips.
Bob
Old Apr 29, 2004 | 12:16 PM
Steve034x4's Avatar
From: North of the Frost Line....near Priddis Alberta
Have a look at the Cabella's web site - I have their combination bug screen and winter front...easy to install, looks good, and not expensive. About $40 bucks for the combo (half that for only the bug screen).
Here's the path
www.cabellas.com > Automotive / ATV > Automotive Exterior > Hood Shields / Body Styling > Summer/Winter Grille Covers and Screen Fronts
Not bad for a fishin' store, eh?
Old May 1, 2004 | 11:48 PM
moopa's Avatar
I made a cheapy bug screen like jnck's for my 98.5, and even while towing heavy,in 90F temps, I never noticed an increase in water temp.Mark
Old May 2, 2004 | 10:50 PM
c172driver's Avatar
Here's the path
Nice site but the correct URL is www.cabelas.com. I'd like to see pics of this combo on a new RAM if anybody has them Forty bucks seems to be worth it.
How do you like your set, Steve034x4?
Old May 3, 2004 | 12:21 PM
Steve034x4's Avatar
I like the set - The snaps were easy to install (they were a "snap" to install ?) and I used two or three of the existing grill screws from the wind deflector I have topside and used adhesive snaps on the lower side. Trick is not to stretch the mesh too much when lining up the screen. Looks good - takes away that front end shine of the standard grill and does a good job catching bugs. About 15mins to install. Doesn't cover the air inlet below the bumper, but my winch takes care of that (advantage goes to the home made version here if you don't have other front end hardware)
The winter front mates up perfectly and washes up easily at end of season.
I've run summer and winter now and I'd buy again from these guys.
No pics yet...hoping to get the dig. camera soon.
Steve
ps. Sorry for the typo, guys.
Gunship Guy
Sep 9, 2003 12:01 PM
nevrenufhp
Dec 23, 2002 02:14 AM
DeaconWayne
Dec 7, 2002 07:35 PM
