Broken Van Aaken V5?
Old 06-24-2007, 05:48 PM
zchornyak's Avatar
I bought the van aaken v5 smartbox off ebay. 200 bucks used. Not a bad deal...if it worked. I just want to make sure i'm not doin something wrong before I throw it back at this guy. I installed it inline with the map sensor and then the diagnostics plug. When I start the truck the check engine light stays on. Ran the code and got a P 1693. When I hit the gas its like a power take off switch. It immediatly shoots the rpms up to about 1500 and stays there no matter how much I press the pedal. There is no in between. Its either 850 or 1500 rpms. I went through and checked all the connections and they are all home and looking fine to me. Is there anything else I should pay attention to? or do I have a messed up box?
Old 06-24-2007, 07:33 PM
smokinstrokes99's Avatar
id say try and get a new one through van aaken or just spend a lil over a 100 more bucks for a new one.
Old 06-24-2007, 09:00 PM
febrocks's Avatar
Do you have the right box? I know mine has part number ending 19982000. It comes w/ instruction for all 2nd gen,98-02. But it's not by the part number. There's enough adapters to make you think it'll fit all years. Something to check. Isn't the P1693 a companion code?
Eugene
Old 06-25-2007, 06:55 AM
Jaxn51's Avatar
Sounds messed up to me. It's a pretty straight forward install.
Old 06-25-2007, 07:44 AM
zchornyak's Avatar
I know there is a ton of adapters, isn't that the only difference between the 98-00 and 01-02 models? The dude on ebay had it advertised for a 2001...I think he really had no idea. I'll probably call up Van Aaken and see if they can tell me which one I have and if they are different.
Old 06-25-2007, 08:38 AM
febrocks's Avatar
No because they got two part numbers on their website. The part number for 98.5-00 is chr-sbxv519982000. Check out your part number on the box. Definitely call them if you don't have that.
The instructions got me thinking that it would work for 01-02. I had to double check because someone ask about mine.
http://vadusa.com/SearchByCategory.aspx?CategoryCode=20
Eugene
edit: I guess I should post other pn:CHR-SBXV520012002.
Old 06-25-2007, 08:49 AM
hopak's Avatar
make sure the plug to the map sensor "clicks" otherwise its not completely connected.
Old 06-25-2007, 09:54 AM
zchornyak's Avatar
I'm gonna hook it up again tonight and check the connections for the third time. I'm not using any adapters and it plugs right in. The 98-00 trucks have different plugs so i'm thinking that I have the right one for the truck. I'll let ya know what V.A. says when I get around to calling them.
Old 06-25-2007, 07:05 PM
the boxes are for 98 to 02 they come with an adapter for the data link, the 98 to 00 is a triangle, the 01,02 is a flat three prong, one being a dumbie prong. i know this because i had to send mine back for the triangle adapter which is supposed to be included
Battering Ram
110
03-25-2004 06:14 PM
BILL DODGE2003
03-08-2004 12:59 PM
Original Junior
01-15-2004 12:26 AM
GLMaines
10-07-2003 09:31 PM
Copenhagenjunkie
05-19-2003 08:04 AM
Quick Reply: Broken Van Aaken V5?
