broken manifold bolts, need a manifold!!!!
Old 04-01-2006, 11:36 AM
Dusty Ratcliff's Avatar
well I had an exhaust leak on my truck............thought it was the gasket between the turbo/manifold, while fixing that I noticed that the back two manifold bolts, top/bottom, were missing, so I pulled one bolt to get the length, threads, etc. & went & picked up two more, got home & went to thread the new bolts in the holes & there was no place to thread them, my manifold I assume from expansion/contraction had moved enough to break the bolts off, & now I believe I am gonna have to put on a new manifold, from the looks of it just holding it up & eyeballing the bolt holes I don't think theres any way to put new bolts back even after I get the broken ones out, so now the ?? is should I go ahead & get a 3 piece manifold?????? & if so what's everyones preferance???? ATS/HTT????????? & what can I expect to pay for a new manifold/gaskets/bolts?????? thanks, Dusty
Old 04-01-2006, 02:14 PM
STACKED's Avatar
if you get the old ones out you can always drill a tap the holes, and drill the manifold out. get some strong bolts like a grade 8.
Old 04-01-2006, 06:09 PM
infidel's Avatar
If you get a ATS it will come with new allan headed bolts.
Old 04-01-2006, 06:13 PM
Geico266's Avatar
I just found my EM to be cracked also. I ordered an ATS 3 piece.
Old 04-01-2006, 07:29 PM
bgilbert's Avatar
ATS manifold (the original 3 pc manifold) $385 from www.scheiddiesel.com. Comes with grade 12.9 allen head bolts, washers, and lock washers. 6 gaskets ~$4.54 each.
Old 04-02-2006, 12:42 AM
checked around a bit today, & I think I'm gonna try & drill out the holes on my old manifold for now, I really hate to drop $400+ if I can fix what I have, I plan on changing out for a 3 piece l8er, but for now I think I'll just make due, thanks alot for the replies, Dusty
Old 04-02-2006, 11:56 AM
2500CTD's Avatar
I got the same thing thing. Back 2 bolts missing/broken. Havent looked to see which yet. Thinking while it off switch to a 3 piece, is there any noticeable gain in the 3 piece, or just wait till I need it?
Old 04-02-2006, 11:08 PM
BARTMAN's Avatar
Guys,
I have a 40,000 mile stock manifold in the garage for whomever wants to pay shipping.
If you buy a ATS, be prepared to fabricate a bracket for the heater hose. All included parts come with the HTT.
Skip H
04-05-2008 07:26 PM
farmerlee
03-24-2008 11:30 AM
shoffs30
04-11-2005 05:54 PM
MADSEN
10-07-2004 09:43 PM
Quick Reply: broken manifold bolts, need a manifold!!!!
