Broken Banjo Line
Broken Banjo Line
On the injection pump, to the right of the diaphram, is a banjo bolt with a u-shaped line that attached to a 90* elbow attached to the intake manifold, (I think it's the intake manifold).
I noticed the line is broken where it attaches to the banjo bolt. I had noticed a fuel smell for about a week prior, but the Cummins seemed to start and run normally. There wasn't a noticable leak either.
How can this be fixed? Can I go to Cummins and get a new part?
Thanks All,
Harley
Thanks All,
Harley
That's the boost line to the AFC, that's why you can't see a leak. Nothing but air in there. Like John said, you might be able to solder it, but you can get a new one from Cummins. You will be pleasantly surprised with the increase in power when you finish your repair.
If that's what you read too, tell me about the gasket! Is it like an o-ring in the fitting that accepts the tube? Or something else?
Where the tube meets the intake 90* fitting... the tube spins inside this fitting and *easily* spins rearward to clear AFC housing once the banjo bolt is removed. IOW, the banjo fitting will swing almost rearward/back against the intake.
Should it? (figure there *may* be some movement allowed so it doesn't break)
Or shouldn't it? (and subsequently leaking?)
Banjo Fixed!
I got the replacement fitting installed today. (Thanks, NYCEGY01!)
In checking the broken end, the break was all tarnished, so it had been that way for some time. I only saw it because I was fiddling with my wiring. A good thing to check because you really wouldn't notice it if it just cracked.
The tube can swivel when the intake fitting is loose.
Thanks,
Harley
Thanks,
Harley
I've heard one can tap the afc cover for 1/8npt then eliminate the hard metal afc line with 1/8npt tubing and fittings on each end.
Caver Dave, you got some cap screws missing on that afc cover .
Yep, it's a leaking. 13mm wrench at the cylinder head, 12mm on the banjo bolt. Do not overtighten!!
Greg (BigWaylon) says the 8mm banjo is PFC to 1/16" NPT... I'd already though about swapping out the hardline for something a bit newer
Uh, that pic is from the 3200 spring install sticky! (was at work and remembered seeing the tube in question)
