Broke Sumthin'
Old 05-06-2008, 05:09 PM
johsonbert's Avatar
Broke Sumthin'
I was backing my 5er up over a curb, back tires on gravel w/ no grip, engage 4H, push her back and hear a bad sound from the front end. I finished the maneuver, and called it a day. Driving to.from work today hear a "tick, tick, tick" from front end. After educated inspection from all the knowledge here, I discovered . . . . .
I broke something. I think like every other fella here and when something breaks it is an opportunity to upgrade. What broke and what to replace with? (Hope the pic attaches) Front drivers side wheel turned right.
Old 05-06-2008, 05:30 PM
rich's Avatar
its a u joint
Old 05-06-2008, 05:38 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
It's a "stub axle to inner axle" u-joint. Common item to break when doing some hardcore offroading. Either replace with a good Spicer or if you want real toughness and rebuildability, replace both sides with a CTM u-joint. Here's the link for what you need: http://www.ctmracing.com/storefront/...7&categoryid=2
But I do believe (not sure tho) that in order to use the CTM, you'll have to do some grinding on the axle shafts.
Old 05-06-2008, 05:51 PM
OOPS's Avatar
CTM joints are great for a rockcrawler or other type comp rig. Not good for a DD whose axles turn all the time. Why, because they do not have needle bearings and need to be greased all the time or you will burn them up. Find a heavy duty joint that has zerk fittings so you can lube them when you service your truck.
Old 05-06-2008, 06:42 PM
johsonbert's Avatar
Thanks for the replies . . . Should I be hunting for replacements in the boneyard? If I replace one side, do I need to do the other?
Old 05-06-2008, 06:51 PM
OOPS's Avatar
No, go to a good auto parts store and get two, heavy duty, greasable u-joints for the front axle.
I would as dry as the one that broke is, the other side is not far behind.
Old 05-06-2008, 06:52 PM
JPR Ram's Avatar
You can replace only one side, but as OPPS stated above, both may be better. But you seriously need to get a NEW one; it's just a U-joint after all. Go to Napa or someplace similar for a Spicer. JMO
Old 05-06-2008, 06:56 PM
johsonbert's Avatar
Okay. Is this the infamous non zerked, non-greasable item on the frontend I have read so about? The one that needs a needle to grease?
Old 05-06-2008, 06:59 PM
06RAM2500's Avatar
Believe thats the one on the front driveline/driveshaft.
smokeum99ta
12-08-2017 01:32 AM
yz
12-31-2002 11:47 PM
Maddog
11-09-2002 11:02 PM
Quick Reply: Broke Sumthin'
