Brand of lift pump..again
Old 12-03-2008, 10:54 PM
thumper549's Avatar
Ok I have to put in an other one , I know this is a old question....But will the best deal please stand up ? !
I see air dogs, air hogs, hollies , carters, OMG ! I do not want to blow my bank acct either !
So, those that truly know..please help me out. I see the Fass as a good unit.......But dang is there some thing a lil cheaper ?
Old 12-03-2008, 11:02 PM
biododge1's Avatar
I have a holley hp 150 on mine. got it from jegs. $250 iirc. it is a gear rotor pump-but it is not loud at all. been runnin for at least a year. it is a 17psi pump, vs. the holley blue or black (10-13psi). and like those, it is rebuildable
Old 12-03-2008, 11:51 PM
thumper549's Avatar
I would go Fass ,,,... but the cash is a limiting factor....
Old 12-04-2008, 12:08 AM
thumper549's Avatar
As of tonight Air dog and Raptor are looking like the vote..what do YOU think ??
Old 12-04-2008, 12:41 AM
Russ Roth's Avatar
I have a raptor. Only been about 4 months but so far so good.
Old 12-04-2008, 01:30 AM
Dennis's Avatar
FASS has the new direct replacement fuel pump. That would probably be fine with just your 275 injectors. I think I saw it listed for under $300. It doesn't have the large flow rates like the others. It is still ratted at like 30% more flow than the stock lp. Just another option for you.
Old 12-04-2008, 01:37 AM
Zeus1987's Avatar
just picked up a AD 100, sitting in the back of the truck right now waiting to go to work. cant beat the deal they have going on at the DTR shop.
Old 12-04-2008, 08:37 AM
jentas's Avatar
Just get the Airdog 100. Those cheaper pumps are not going to help with cavitation. When worrying about the extra cost, you should think about how cavitation reduces the life and performance of expensive components like the injectors and vp44.
Old 12-04-2008, 03:42 PM
Bullet112233's Avatar
Airdog 100
Guy on ebay has the Airdog 100 for $375 after $125 rebate from microsoft live search. I just bought one for my 04. It was a little bit of a pain for the rebate, but only took me like 10 minutes to fill out the form.
Old 12-04-2008, 03:57 PM
rollincoal01's Avatar
Been running my holley black pump for about 2 years now. No problems so far. I run it in series with a replacement in tank pump(warranty when I worked at the dealership). It runs AWESOME!!! My buddy with an 03 HO truck put the real expensive fass setup on his, and it works fine. The only thing he hates about it, he said the replacement filters are like $30 a piece. Just throwing in my two pennys.
Tommy
Old 12-04-2008, 07:09 PM
thumper549's Avatar
decisions decisions...........wish I had a endless amount of cash but this trk has sucked me dry...
Old 12-04-2008, 07:49 PM
nitrousn's Avatar
Unless your truck is a hot rod I would go with the airtex. I find most of this super duper pumps a bunch of wasted money. Why does one need a pump so big that it could power a rocket ship to the moon. Makes no sense to me. Once you can read through all the myths and mis information let alone mis-diagnostics of the VP44 system you will see the true facts.
Old 12-04-2008, 08:00 PM
Number47's Avatar
i just bought a raptor because the holley blue i had on died and i had it on for less than 5 mounths
Old 12-04-2008, 10:09 PM
jentas's Avatar
Do you work for airtex? How is spending a little more than twice what a pos airtex costs on product that will last the life of your truck, reduce cavitation, and replace all the restrictive stock fuel line and fittings a waste of money? It seems like people are posting up plenty of problems with airtex failures, just like the carters, and even when they spend the extra money and time to relocate them to the frame rail.
Have fun being stranded or swapping out your dead airtex on the side of the road in the dead of winter. Or maybe you'll just keep driving it home with a dead lift pump because it's just a myth that driving with a dead lift pump is one of the main causes of the vp failure.
Old 12-05-2008, 11:31 AM
nkennedy's Avatar
I vote for the new FASS DDRP. Around $255 I believe. I have a Carter pump installed & 1 spare, but when they die it's a DDRP for me.
Quick Reply: Brand of lift pump..again
