What brand lift blocks do you have on 3rd gen?
Old 03-29-2007, 08:59 AM
SolarYellow05's Avatar
I just installed a 5 inch rough country x-series on my 2005. The lift blocks for the rear do not work correctly with the two centering pins in the leaf springs. Does anyone have lift blocks that are drilled for these two pins instead of the plastic locator that's in the place of a typical center pin?
Old 03-29-2007, 09:05 AM
Pooter's Avatar
My superlift blocks are open in the front/back center area, and has the pin/hole for the springs already cast in.
I will be swapping to springs though, as soon as I get the extra money.(Either add-a-leaves, or maybe lorenz/carli mini pack)
Old 03-29-2007, 09:29 AM
Mine also has the pin/hole but the hole is too small for the factory plastic alignment pin and the pin is too small for the hole in the spring perch on the axle.
Old 03-29-2007, 10:25 AM
expressfish's Avatar
I couldnt find any in one inch, so I fabbed a set myself. My brother works for outback offroad and ordered several 2" block sets and none of them were correct.
Old 03-29-2007, 10:58 AM
skynyrd's Avatar
i got my 2 " set from jackit.com and they lined up great i didn't have any problems with the alignment pins
Old 03-29-2007, 03:21 PM
ataboy9026's Avatar
My 1" blocks are from Fabtech. They fit perfectly.
PourinDiesel
Competition / Pulls / OffRoad
20
03-12-2008 02:50 AM
PourinDiesel
0
02-15-2008 10:06 AM
Katmandu
01-16-2006 08:30 AM
Quick Reply: What brand lift blocks do you have on 3rd gen?
