Brakes
Old 03-13-2004, 06:29 PM
perk's Avatar
Brakes
I am looking at doing brakes here soon. What type of pads do you recomend? What are the tollerances on the rotors and Drums? I will proabably have a friend that is a machinist turn them down for me, he ows me for redoing a floor.
Old 03-16-2004, 09:29 AM
infidel's Avatar
Give Ram brake expert Sam Peterson a call M-F 8-5 pacific 360 357 4958 he'll set you up with pads that exactly match our trucks for the best deal going. Includes new pins, lube and anti-squeak for the price most charge for just pads.
I wouldn't turn the rotors unless they are scored, there is no reason to.
If they are warped replace them as the warp will likely come right back.
Old 03-16-2004, 03:55 PM
Palmetto_kid's Avatar
anit-squeek lube? i just put new Napa pads on (the 80 dollar lifetime warranty set) and they squeek like its going out of style!!!!
where can i get this lube?
Old 03-16-2004, 04:15 PM
firestorm's Avatar
Two things I have done, and they both work is, Apply the red RTV gasket maker to the back side of the pads, before installing. Or for a better job, spray the back of the pads with the 'disk brake quiet'. You can get either at any auto parts store.
Old 03-16-2004, 06:02 PM
infidel's Avatar
firestorm gives good advice.
Many times brake pads that are too hard for our rotors will squeak and also wear the rotor. But the pads will last.
One of the reasons I'm leery of lifetime pads, I'd rather replace pads than rotors.
Old 03-16-2004, 07:20 PM
nevrenufhp's Avatar
I just put in some cheapies and didn't turn the rotors, the first and last time that'll ever happen. Sounds like fingernails on a chalkboard mixed with a rock jammed in the rotor. I usually go all out for brake jobs, & just slap myself for doing it this way. I've heard good stuff about the NAPA ceramix ones. I'll try those or the "z rated" from parts america(schucks/kragen/checker).
Old 03-17-2004, 09:55 AM
Cowhand's Avatar
I was looking at the ceramic pads myself, but the guy at my local independent part store told me the ceramics (at least the ones he stocked) were very hard on rotors in the heavier trucks. He sold me on the carbon metallics. I put them on with new rotors, and so far I can't say I'm nuts about the pedal feel but they're quiet and they stop as well as any other pads I've used. We'll have to see how they wear.....
wildcargo
11-29-2005 04:20 AM
95black2615
08-22-2005 09:21 AM
JImbo1
13
04-18-2003 06:44 AM
Quick Reply: Brakes
