Brake Question
Old 01-03-2010, 04:36 PM
Dlowkes7's Avatar
Brake Question
I have been working on my truck, and only a few thing left before i put her on the road.
One issue i have is that the truck has no brakes. I mean when i drove it across the yard, not even on the gas, i cringed when i put all my might into to pedal to make this hog stop.
My question is.. ... is this a bleeding issue?
... booster issue?
I forgot to check the vacuum today at the pump.
Old 01-03-2010, 05:23 PM
Trebor's Avatar
That's the first place I would check if the brakes work but lack the power assist.
Old 01-03-2010, 05:32 PM
On an intercooled truck the problem is more likely a big vacuum leak (hose off, bad brake booster) than a failed vacuum pump.
Old 01-03-2010, 05:34 PM
Kansascrewcab76's Avatar
How was the pedal?
Soft, goes all the way to the floor, hard as a rock???
Little more info is needed
Old 01-03-2010, 06:56 PM
sdseva's Avatar
he mentioned "all his might" on the pedal so i would say a hard pedal. mine had the same issue not to long back. i traced the vacuum leak to my booster, replaced it and now my pedal is perfect.
Old 01-03-2010, 07:06 PM
RuralCruiser007's Avatar
Worse case scenario, talking about hard pedal, is that someone put oil in the brake fluid and now everything is swollen. Replace everything. No choice in that matter. Oil makes every rubber component swell like a pregnant pig. From front to back and top to bottom.
Take the master cylinder cap off. Is it swollen and funky? If so then someone has put oil in the master cylinder. Sorry but start a parts list and replace everything that has rubber in it.
Last edited by RuralCruiser007; 01-03-2010 at 07:10 PM. Reason: Forgot about the master cylinder check.
Old 01-03-2010, 08:53 PM
Dlowkes7's Avatar
Ya the pedal is very hard.
Any model number on the booster?
Old 01-04-2010, 05:30 PM
Get a loaded booster from your local auto parts store. Fluid from a bad master is what usually kills the booster.
Old 01-04-2010, 06:43 PM
Dlowkes7's Avatar
What is the difference of a loaded booster and a regular booster.
Old 01-04-2010, 08:01 PM
HappyCamper's Avatar
Loaded booster is one that already has the master cylinder attached.
Old 01-04-2010, 08:04 PM
jimbo486's Avatar
so in other words, a new booster and master cylinder should fix the problem. don't forget to bleed the master before you install it.
Old 01-04-2010, 10:23 PM
Dlowkes7's Avatar
i hope i have a vacuum leak. i priced out just the booster for 99 at napa, i guess i will price out the whole unit tomorrow
Old 01-07-2010, 03:51 PM
Dlowkes7's Avatar
Ok so today I ordered a loaded booster.
I took the boost/Vacuum gauge out of my car and attached it to where the cruise control vac line goes. It only pulled about 8 hg but I didn't block off the booster or the other line. If the booster was bad would it hurt the reading? Or would it still reflect the vacuum pressure.
Vacuum increased to about 10 or 11 hg when throttle was applied
Also does anyone have a picture or diagram of all the vac lines?
Old 01-07-2010, 05:43 PM
Yes, a leak would cause low vacuum. Connect directly to the pump to make sure it's OK.
coalburner400
08-01-2006 06:37 PM
2500TurboDodge
06-28-2005 09:52 PM
ddestruel
04-06-2005 11:26 AM
wvcowhauler
13
04-03-2005 11:39 PM
Quick Reply: Brake Question
