Brake line replacement
Old 09-26-2009, 05:16 PM
I SPEED's Avatar
Easiest way (read...quickest) to replace the long hard line (the one that runs behind the fuel tank)?
I bought a replacement from the dealer...not bad, less than $30.00.
Really don't want to drop the tank.
Old 09-27-2009, 05:46 AM
RPegram's Avatar
A piece of steel brake line long enough to replace section you want and 2 couplings with compression ends. Cut out old, slide in new, put on fittings and bleed brakes. Use tubing cutter on lines. Takes about 30 minutes.
Old 09-27-2009, 08:14 AM
I SPEED's Avatar
Thanks, but no thanks. I will not use compression fittings on any brake line, let alone my truck.
Safety is my first concern, not to mention they are illegal on brake lines in most states.
Old 09-27-2009, 11:23 AM
SWC
SWC's Avatar
EGR brakes make replacement brake lines for our trucks.
I got a set from them for the rear axle. Dealerships here in Canada wanted close to $1000 with tax for the two lines.
EGR's price with exhange and shipping under $350.
Excellent service.
Stan
Old 09-27-2009, 01:43 PM
I SPEED's Avatar
Excellent service.
Stan
The lines on the rear axle are expensive here too...would be close to $600.00 from the dealership.
Old 09-27-2009, 09:32 PM
roughstock's Avatar
I dropped the tank. I also had the bed off at the same time. Was converting from pickup box to flatbed
I just got straight brake line and bent it my self
Old 09-28-2009, 07:31 AM
patdaly's Avatar
I would personally straighten the back section enough to get it behind the tank, tape off the end so junk doesn't get in there, and shove it through. I have done 3 so far, not an issue with any.
weiercd
11-22-2013 07:54 PM
mini14
08-13-2009 03:49 PM
~Angry Tractor~
09-23-2007 07:12 PM
~Angry Tractor~
09-22-2007 09:38 PM
Quick Reply: Brake line replacement
