brake lights stay on
Old Nov 23, 2008 | 09:05 AM
ryan10's Avatar
Hey guys, i have a 97 3500 gas job that the brake lights always stay on. The problem is that the brake pedal sags and hits the brake light switch. How do i fix this?
thanks
Old Nov 23, 2008 | 09:13 AM
hamilton71801's Avatar
I believe you can fix it with a new brake light switch. I got mine at Auto Zone for $15 and you have to preset it to your truck so it should take up the slack. Its worth a try just follow the instructions.
Old Nov 23, 2008 | 04:19 PM
sjester's Avatar
Sometimes you can adjust your existing brake switch without buying a new one. Have done that a time or two. I thing the procedure could be found with a search here, but as I recall I lifted my brake pedal up and then pulled the switch trigger up a couple of clicks towards the pedal. Brake lights were staying on and cruise wouldn't work prior to the adjustment. You can search on the cruise topic also and find some info on adjusting the brake switch
Old Nov 23, 2008 | 06:39 PM
infidel's Avatar
Sounds like you have more than a switch problem.
Perhaps the pedal return spring is broken.
Old Nov 24, 2008 | 02:51 PM
ryan10's Avatar
I adjusted the switch and it works great now.
thanks guys
CTD NUT
30
Jun 25, 2019 07:14 PM
Flying Circus
May 1, 2009 12:43 AM
rbrettctd
Aug 18, 2008 10:07 PM
BearKiller
Jan 11, 2008 07:46 PM
