brake light & abs as well
Old 03-06-2010, 09:48 PM
b1mmuo27's Avatar
Mine is similar to the previous post with the following exception. I had a draw tite flip ball gooseneck hitch installed this week. The guy said he didn't think I had the clearance to put the ball in upside down. Should have listened. I measured almost 3 inches from the bottom of the bed to the top of the axle. Well bang bang it sheared the right rear brake line in half. I replaced that today as well as the wheel cylinder. After bleeding the brakes with the engine off I now have the ABS light on & the brake light on. What will reset that? Battery off? Everything is fine & the brakes are working fine again. Parking brake is not dragging.
Old 03-07-2010, 06:47 AM
dkenny's Avatar
did it get the speed sensor mount in the differential as well?
this sensor will cause the brake and abs lights to light.
-dkenny
Old 03-07-2010, 09:41 AM
b1mmuo27's Avatar
No. I drove it for a day with it snapped in half with no lights on. They only came on after I replaced the wheel cylinder & bled the lines.
Old 03-07-2010, 09:56 PM
b1mmuo27's Avatar
One other thing that was odd, when the line sheared in half the differential valve did work or I wouldn't had any brakes yet the brake light never came on. It only came on after the wheel cylinder was replaced & the whole line from the master cylinder to the wheel cylinder was bleed.
Old 03-08-2010, 12:25 PM
sheriffav8r's Avatar
Still, check the condition and continuity of the ABS sensor line. That's what sets off both of those lights....
Old 03-08-2010, 12:40 PM
b1mmuo27's Avatar
Turns out it is a bad abs switch at the master cylinder. Literally broken. Replaced & good as new. Thanks
azjeff
08-04-2012 09:57 AM
Joey-D
12-12-2011 12:52 PM
BigBore050
03-09-2010 11:46 PM
mr T
02-24-2007 06:42 AM
Alexjoz
09-01-2005 10:00 PM
Quick Reply: brake light & abs as well
