brake hydro boost leaking a little coolant
Not exactly sure where the leak is. I wanted to know if this was something routine/common or a really expensive job coming at me.
Routine leak is OIL from the seal between the power steering pump & the vacuum pump. That can be easily fixed. fixin rams has details or you can buy the seal elsewhere & figure it out yourself (perhaps). Repair is much cheaper than replacing even if you pay Peter for his knowledge. Clean yours up & find the leak.
