Brake fluid question
Old 01-22-2007, 11:54 PM
hipsi's Avatar
Its too cold/no time right now to change the brake fluid.... however if i just suck out the fluid in the resiviour and fill it up with fresh fluid is this going to benifit the system at all until i can make the bleed and put in fresh fluid in a month or so?
Old 01-23-2007, 10:00 AM
infidel's Avatar
I see no reason why not as long as you follow though on the bleeding later.
I would consider the new fluid you add today to be old fluid when you bleed and replace it with new when the time comes.
Old 01-23-2007, 12:35 PM
TIMMY22's Avatar
when you bleed it just open the bleeder screws one at a time and let gravity drain it out. it you go crazy pumping the pedal, you are likely to damage the master buy sending the primary piston into a bunch of grit thats built up over the years. the normal stroke is a fraction of an inch when you hit the pedal.
Old 01-27-2007, 09:49 AM
hipsi's Avatar
thanks for the input.. yea the new fluid I add is for sure trash after it touches the old stuff
Old 01-27-2007, 10:55 AM
d0dg301's Avatar
After how many miles should one change their brake fluid. And is it really necessary?
Old 01-27-2007, 11:59 AM
infidel's Avatar
Brake fluid is a water magnet (hygroscopic). If you want to avoid problems due to rust and contamination change and flush your fluid every couple years.
Old 01-28-2007, 04:13 PM
CochranD's Avatar
Thumbs up
Im ashamed to admit that I just changed mine for the first time this summer.
It came out looking like old engine oil. I flushed the old stuff out entirely, wiped the can out and refilled with synethic. The peddle pressure difference was noticibly different.
If you havent dont it lately, I would do it .
Old 01-30-2007, 10:27 PM
daysel's Avatar
ya'll using synthetic dot 3 or what? I think I have a few quarts of it in the garage. Guess i'll do the 1 ton cylinder upgrade while im at it.
Old 01-30-2007, 10:57 PM
Marine's Avatar
Use the Dot classification your brakes call for. If you use a silicone based brake fluid, it does compress under pressure, whereas normal brake fluid does not. However, normal brake fluid is hygroscopic.
Old 02-01-2007, 03:24 PM
01RAMer's Avatar
Old trick, put a piece of 2x4 under the pedal to keep the pedal from going alll the way to the floor when bleeding.
LockedandLoaded
01-17-2008 02:51 PM
Tommy93w350
06-26-2007 04:42 PM
2500
10-02-2006 09:14 PM
icrider
09-27-2006 03:10 PM
mr T
10-16-2005 07:38 PM
Quick Reply: Brake fluid question
