Brake bleeder help
Old 09-27-2008, 02:03 PM
TedT's Avatar
Unhappy Brake bleeder help
My brake fluid is getting dark and I'd like to flush it. I tried to loosen the left front bleeder but it is very tight and I broke it off. I tried the left front and it is very tight. I stopped before breaking it. How would you suggest removing the broken one and how do I get the other three loose without breaking them.
Thanks, Ted
Old 09-27-2008, 03:42 PM
lawnmaniac883's Avatar
Step 1 soak them bad boys with some PB blaster penetrating oil do this the night before and about a half hour before you try to loosen the bleeders, worked for me and I just did a brake job on mine earlier this week.
As for removing the broken bleeder I'm not sure you can I remember reading of members here having to replace the entire caliper instead.
Old 09-27-2008, 05:41 PM
Langetough's Avatar
You can try a extractor bit. Craftsman makes a really good one that works perfect for me. If you don't already have them, next time get the brake line wrenches. They prevent damaging the brake brass pieces.
Old 09-27-2008, 07:46 PM
D68
D68's Avatar
i never seen brass brake pieces??? look bleeders arready brock try a easy out on the broke bleeder should come right out.
DmaxDouglass
01-06-2010 12:15 PM
dodge35000
09-26-2009 03:16 PM
billv45
08-28-2008 12:14 PM
Bad Ramer Jamer
01-10-2008 03:40 PM
Dave88LX
11-19-2005 02:55 PM
Quick Reply: Brake bleeder help
