brake/abs question???
Old Aug 2, 2004 | 12:46 PM
apache's Avatar
On our trip to oregon we noticed a fairly loud clicking comming from what seems to be the right front wheel. Its definatly in sync with the tire rotation and dosent go away when the brakes are applied. I was thinking we were loosing a wheel bearing but I jacked it up and spinning it, it sounds OK. Also occasionally the ABS and also the brake light would flash on for a second. Im gonna tear it down tonight, but Im not to savvy on ABS issues. Any Ideas??
Old Aug 2, 2004 | 08:38 PM
dodgenstein's Avatar
ABS on a 93 is rear axle only.
Old Aug 2, 2004 | 08:42 PM
Garz's Avatar
You sure it wasn't a rock or screw in your tire treads?
Old Aug 2, 2004 | 09:20 PM
apache's Avatar
Well it actually did it once before on a trip. it seems it has to be driven a lot before it starts in. I tore both sides down this pm and no signs of anything. Im beginning to wonder, but as I mentioned the brake and ABS light came on this time.
Old Aug 7, 2004 | 08:46 AM
uncleroty's Avatar
As dodgenstein mentioned above, ABS is rear wheel on a 93. If the bearings look good, and there's nothing in the tires, then I'm at a loss to explain it. were the hubs completely unlocked? Maybe that's it. Good luck with it though.
Old Aug 7, 2004 | 09:13 AM
apache's Avatar
Never did find the cause, replaced the rotors and pads and bgs. must be a fluke with the ABS light
Old Aug 11, 2004 | 09:02 AM
Nuttymopar's Avatar
You can also disconnect the ABS connector behind the Glove Box for 10 or 20 seconds to reset the ABS. Doesn't hurt to have the battery disconnected also to reset everything.
Brake light also comes on if you have a bad Vacuum Switch located on the Drivers fender under the hood right at the Hood bracket. If you get below 8.5 HG? it will cause Brake light to go on. Mine was rusty underneath the switch and needed to replace.
fitzydog
21
Oct 11, 2017 12:09 PM
BigBore050
Mar 9, 2010 11:46 PM
kpmccarthy
Apr 23, 2008 07:42 AM
BobQ
Sep 13, 2007 07:21 PM
mr T
Feb 24, 2007 06:42 AM
