? bout VP44 and fuel pressure
Old 03-27-2007, 07:44 AM
Firemanhoser's Avatar
I'm getting ready to replace my vp.
I have noticed in the last two weeks that I'm starting to blow more black smoke in stock mode. Might there be a reason for that?
I have also noted that on my Att. monitor. That my fuel pressure will vary from 14-12 or 15-13 psi. I tend to run down the road with 11 psi. This is all on a new lift stock lift pump. Is this normal?
I'm replaceing my vp because of dead pedal and my engine will slightly cut out while pulling the fifth wheel. If I put it in level 1 or 2 I will get bad dead pedal. But barely notice it on stock. (this is with the fifth wheel on.)
Also the other day, taken off in 1st gear. I got white smoke and the engine miss fired.
I went on a little more than I planned for this topic. But just wondering what others thought.
Old 03-27-2007, 07:49 AM
Geico266's Avatar
Warmer air means less oxygen in the air = more black smoke when warmer.
Fuel pressure readings are normal.
Old 03-27-2007, 12:41 PM
PaulDaisy's Avatar
It must be bad to live in AZ then. How do people breathe there in the summer if there's less oxygen in the air?
-P
Old 03-27-2007, 12:45 PM
Mike D's Avatar
Don't pick on the caveman..
Old 03-27-2007, 06:23 PM
kwhite's Avatar
So, is the lift pump the same as the injector pump?? I have a 2000 model 1 ton and I am thinking mine is going bad. I get slow take-off and it just doesn't seem like its got very much power.
Thanks,
Old 03-27-2007, 07:48 PM
badme's Avatar
Go read this post
https://www.dieseltruckresource.com/...d.php?t=139601
Old 03-27-2007, 08:00 PM
AllanP's Avatar
Thanks,
No they are not the same thing and they sure are not the same $$$$$.
First and most important mod is a fuel pressure guage.
Old 03-27-2007, 10:44 PM
zulusafari's Avatar
Don't forget to check for trouble codes. Maybe it is something simple and much cheaper than the VP44, like a MAP sensor. Check for codes and then see what needs fixing. If there aren't any codes, we arm-chair types may start throwing out theories, but we do so with all best intentions. Good luck with the truck, and keep us informed!!
12valvin
08-10-2011 09:24 PM
deerefarm06
07-18-2007 04:41 PM
600 Megawatts
01-22-2005 04:53 PM
Quick Reply: ? bout VP44 and fuel pressure
