bought a engine need rebuild
well guys i bought me 97 12 valve from a standard truck and i am needing to rebuild it itr is using alot of oil!! i am building this engine for my new power plant to use in my custom 6x6 hauler truck 25,000 max towing it will be a twin turbo hp p-pump mated to a mercedes g56 so i know i will need to fire ring or O ring the head along with head studs but i am needing to know where i can get a suit case kit for it and if there is anything i should do to the bottom end cam or the head other than the fire rings/O ring and the studs like valve springs or such this will be m,y first time rebuilding a diesel i have allways been a big block and hemi guy so any input is greatly appreciated
JC
JC
chevummins
12-23-2010 10:33 AM
swampthang
07-25-2007 12:15 AM
