Boost
Boost
How many pouds of boost can i expect to get out of my stock truck. i am trying to decided if i need a 35lb gauge or a 60lb.... i might add a power mod or two in the futture, but not for sure.
Even a stoc truck with a boost fooler... how much would it produce with that? more than 35lbs?
My truck has the Bully Dog Triple Dog installed. Suppose to have the Crazy Larry tune, but I can't tell and I never use it. However, I can only make around 25lbs of boost. I once saw 32 for a split second on the Outlook Monitor, but I've never been able to get it to do it again. Normally it goes to 25 or so and settles in at 23lbs. I'm wondering if a boost fooler will help. Will it hurt the truck? I'm getting nervous about wreckin' the trans. I run two, and only performance once in a while. I never do boosted launches. Thoughts?
It sounds to me as though the BDTD is not boost fooling and therefore you could probably use a boost fooler. Still doesn't make much sense why you are only seeing 25# though. As far as a boost fooler hurting the truck, I would say not if you use it sensibly. On the other hand, any time you are putting out more than stock power, you have put yourself in a position to break things with the stock auto tranny being very high on that list. It won't last very long if you're beating on it. You play-You pay.
Well I read today that the BDTD is not boost fooling. So that makes sense. I'm tempted to unload it and see what it does. Wonder if my older CL program I downloaded is wacked. Sounds like a boost fooler is in order.
I realize you pay to play, but you can be reasonable about things too. I've been more worried about injectors and such these days. Really don't want to go through that.
I do believe that the stock Turbo is only rated at 40psi max. I have had mine close to that 38psi on several occasions. I do run a boost fooler to get that high.
HOHN
45
10-08-2005 08:51 AM
triplenickel
08-23-2005 04:01 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
