boost problem
Old Feb 26, 2008 | 04:52 PM
kyle_truck_pull's Avatar
Exclamation boost problem
guy has a 99 24 valve, the waste gate is not hooked up to the turbo it has a plug in the turbo and the line is still there. if the waste gate is not hooked up can it still cause problems? does it do anything else. the reason i ask is he is having problems building boost and lack of power. i havent looked at the truck yet but i think he may be having a fuel prob. but i just wanted to know if the waste gate does anything else when it it not plummed into the turbo. thanks-sorry if this seem confusing
Old Feb 26, 2008 | 08:29 PM
Number47's Avatar
having the wastegate unhooked will not affect power. its going to allow for "extra" boost. Do you have excessive black smoke if you do look for a boost leak
Old Feb 27, 2008 | 04:21 AM
Fishin2Deep4U's Avatar
I assume you mean the boost signal is disconnected from the actuator. In this case, it will build boost until the drive pressure can overcome the wastegate.
If the actuator is unhooked and the flapper arm is floating, it'll never make any boost.
Dave
HOHN
45
Oct 8, 2005 08:51 AM
triplenickel
Aug 23, 2005 04:01 PM
GTSDave
Jul 8, 2005 09:06 AM
MY WORLD
25
Dec 29, 2004 08:54 PM
Palmetto_kid
Jan 16, 2004 02:21 PM
