Boost levels with 305/555?
Old 01-05-2007, 12:44 AM
rfinn04's Avatar
I currently am running a 2003 dodge 305/555 auto, with edge juice/attitude and boost elbow. my max levels of boost via attitude monitor range from 28-30psi seems kinda low to me. Just curious what you guys are achieving. any post would be great. thanks
Old 01-05-2007, 12:59 AM
morkable's Avatar
Thats all you will get with the stock turbo, I did everything and thats it on the 03. We dont get what the 600-610 gets
Kevin
Old 01-05-2007, 03:01 AM
DODGER BOMBER's Avatar
i can hit 44 on my stock 03 turbo with a boost fooler.
Old 01-05-2007, 10:20 AM
morkable's Avatar
Oh yeah, I never put the edge on til after the new turbo, my bad
Kevin
Old 01-05-2007, 10:54 PM
rfinn04's Avatar
why do you guys suppose i am not making any more boost than 30psi.
Old 01-05-2007, 10:59 PM
CG98x's Avatar
My 03 had no trouble getting around 35 psi with my Van Aken 3.2 stacked with my ez. With just the EZ and boost elbow I could get 32 psi.
Old 01-05-2007, 11:05 PM
KBennett's Avatar
Where are you getting the boost info? From a gauge or the Attitude?
If it's from the Attitude, it may be incorrect due to the MAP sensor.
According to my Autometer gauge I have gotten over 30 psi with mine on level 5 without a boost elbow. I don't pay much attention to the boost number on the Attitude.
Old 01-06-2007, 12:12 PM
C Schomer's Avatar
The stock muffler might be hurting the boost. I get 36psi. Craig
Old 01-07-2007, 07:06 PM
MikeyB's Avatar
I'm showing 34psi with my 35psi Westach gauge with the SMARTY, adjustable boost elbow and the Edge EZ for a boost fooler. Possibility I could be higher than what the gauge is indicating.
MikeyB
Old 01-07-2007, 10:45 PM
rfinn04's Avatar
I get my reading from my attitude. I previously had a tst cr47 and it read the same. Do you think opening up the exhaust would help?
Old 01-07-2007, 11:43 PM
KBennett's Avatar
The Edge and the TST both get there reading from the MAP sensor.
No. Our exhaust is not that restrictive. Have you played with the fueling settings on the Edge?
Old 01-08-2007, 01:05 AM
opening the exhaust will just help it flow. Before the boost fooler i could only get 25psi with no chip or programer. I can get 30-34 with just a programer on 90hp setting.
Old 01-08-2007, 09:58 AM
rfinn04's Avatar
Yeah i have the low boost fueling turned all the way up on the edge. Is it possible that the map sensor is bad or out of range but not enough to throw any codes?
Dodgezilla
12-10-2010 02:25 PM
BluesCuda
08-02-2009 09:47 AM
03CTDCO
02-27-2005 05:08 PM
Lsufan78
28
06-02-2004 08:06 PM
03CumminZ4X4
04-08-2004 04:58 PM
Quick Reply: Boost levels with 305/555?
