Boost gauge needle oscillating ???
Old 02-12-2010, 03:39 PM
msiminoff's Avatar
I just noticed today that my boost needle oscillates whenever the boost is between 10 and 25psi. It is rock solid above and below those pressures. The movement amounts to something like plus and minus 1/2 psi (1psi total movement) and it is pretty fast... the tip of the needle is basically a blur.
Has anybody seen this before? Do I have a bad gauge? Bad hose? Or is it indicative of some other intake problem?
By the way this is an Auto Meter "Phantom" 2-1/16" 0-35PSI mechanical boost gauge. It is run into a "boost bolt" in the intake manifold.
-Mark
Old 02-12-2010, 04:48 PM
Smalz's Avatar
YA mine does the same thing. I have the same gauge as you. I went through and checked connections found nothing.
Old 02-13-2010, 11:01 PM
blacksmoke06''s Avatar
I have the 60psi gauge and mine does the exact same thing. Checked mine also and found nothing wrong.
Old 02-14-2010, 12:35 PM
CRToney's Avatar
Same thing here too. I was told that because of the location of the boost bolt and that the pressure fluctuates because of the opening and closing of the valves of the closest cylinder.
Old 02-14-2010, 02:10 PM
msiminoff's Avatar
Okay, thanks for the feedback so far. Funny thing is, I don't recall the needle bouncing before... and the gauge has been there for more than 2 years. Maybe my eyes are getting old
Anyway, I am going to move the boost tube to a port on my (Pusher) intake horn and see if there's any difference.
-Mark
Old 04-04-2010, 08:16 PM
msiminoff's Avatar
Problem Solved!
I took out the boost bolt and moved the pressure tube to a port on my intake horn. Now the pressure reading is stable regardless of the boost pressure.
-Mark
Old 04-07-2010, 12:33 AM
Marcus's Avatar
I have a similar problem now and had it a couple years ago, I found a cracked boost line at the gauge; it would flutter at high boost. I havent looked into the current problem....yet.
trex
10-11-2006 08:44 PM
piperca
07-04-2006 04:13 PM
Big Wolf
04-26-2006 11:02 AM
SolarYellow05
04-09-2006 05:39 AM
RonP
04-24-2005 07:00 PM
Quick Reply: Boost gauge needle oscillating ???
