Boost Fooler
Old 02-11-2010, 12:58 PM
Redneck24V's Avatar
Boost Fooler
Here is a dumb question, but I am confused, how can I run a boost fooler with an edge comp, can I just plug it inline, or what do I need to do or buy??
Old 02-11-2010, 01:21 PM
Redneck24V's Avatar
And the reason I ask is because my truck isnt making much boost and seems to be in a limp mode because it is pulling the p0234 code which is Engine Overboost Condition. When it runs good in makes about 38 psi, right now only about 18 psi, and running bad.
Old 02-11-2010, 02:58 PM
high bid's Avatar
Double check...doesn't the Edge Comp "boost fool" the ECM? If not, then yes you'll need to have the boost fooler installed. Should install inline. If that does not work then you may have a intercooler boot loose/cracked/blown.
Here's an off the wall cool link I just found
http://www.tibor.org/fuel-box.html
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: Boost Fooler
