boost fooler
Old 08-28-2007, 09:31 PM
RamMan05's Avatar
boost fooler
how exactly does a boost fooler work and is it something good to have? i dont have a programmer or anything yet but plan on getting a smarty after i get the money up for it. will it help out for now on my pretty much stock truck
Old 08-29-2007, 09:51 AM
DTR 1st Sergeant
soulezoo's Avatar
essentially the boost fooler works by "fooling" the ecm from the signal sent to it by the MAP sensor. This allows you to run more boost than stock without setting an overboost code because the ecm now thinks you are making less boost that what you really are. It will absolutely help with any box/programmer that does not do its own fooling. It will help only a little bit on a stock truck to the extent the stock fueling will allow you to spin the turbo that much more. I think it's a good thing to have in your back pocket for when when you need it in the future, but not absolutely necessary where you are at right now.
Old 08-29-2007, 11:26 AM
05CTDN8's Avatar
I am running the Xzillarator Race Box which I am told does boost fooling. Before the box I would see 28PSI tops on my analog gauge. Now I can peg 35+ quick!
Old 08-29-2007, 07:29 PM
RamMan05's Avatar
does the smarty do it's own boost fooling?
Old 08-29-2007, 07:33 PM
DTR 1st Sergeant
soulezoo's Avatar
I think the beta versions do, I am not sure about the published versions. I had the quad boost fooler before the smarty so I never knew the difference.
Old 08-29-2007, 07:39 PM
RamMan05's Avatar
and one more thing. does it really lower exhaust temps like it says?
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: boost fooler
