Boost Fooler
Old 10-13-2006, 02:59 PM
wimpy76's Avatar
Boost Fooler
Installed boost fooler and still not getting above 32psi. Also when I hit 32psi Iam having to back out of the throttle because egt's and still have about half the pedal left, what do I do?
Old 10-13-2006, 03:11 PM
MikeyB's Avatar
What's your EGTs?
MikeyB
Old 10-13-2006, 03:19 PM
dodgezilla04's Avatar
what is the condition of your air filter? a dirty filter will not allow air to flow and will increase your egts.
a clogging fuel filter will also not fuel well and that will reduce boost since spool is dependent on fuel burning generating exhaust gases. but, you probably did that.
Old 10-13-2006, 04:25 PM
wimpy76's Avatar
MIkeyb: I am backing out at 1350
Dodge: air filter has 3000 miles on it put on after gauges because I thought it was to hot... fuel filter just replaced two days ago to try to eliminate that one
Old 10-13-2006, 05:00 PM
told you that you had already checked those.
have you checked intake piping for loose clamps, leaks, hoses, or that plastic intercooler on the front of your '05?
Old 10-13-2006, 05:07 PM
wimpy76's Avatar
What plastic thats a first for me? I will check everything else.
Old 10-13-2006, 05:12 PM
the earlier 05's had plastic crimped end tanks on them. they were trouble at first with blowing the cores. look at the crimps.
Old 10-13-2006, 06:46 PM
wimpy76's Avatar
Bought my 05 in july of 05 so should be the later of the 05s checked to see if the end caps are plastic and they are not. I am lost building 30lbs of boost but no more and i am running the SC 3805 with the boost fooler. Why aint i getting more boost.
Old 10-13-2006, 08:38 PM
rustyshakelford's Avatar
somethings going on...i get 39-40psi WOT from my sc and i dont have a boost fooler. is it possible your gauge or tubing is malfunctioning?
brett
Old 10-13-2006, 09:53 PM
jwtuc's Avatar
Uh , maybe the boost fooler is not working . Don't take that the wrong way . For me , I will spend hours trying to solve a problem and the answer is usually something simple .
Old 10-13-2006, 10:03 PM
HaulinBut's Avatar
What's your altitude there? I've been doing alot of traveling, and have noticed a huge difference to how high the EGTs get because of that. I love living at 8500 ft.a.s.l., but turbos really suffer.
Old 10-13-2006, 10:06 PM
wimpy76's Avatar
We are 4500 feet but towing into 10000 plus with 11k 5th wheel, but why cant I pull more boost?
Old 10-14-2006, 01:42 AM
TAS05CTD610's Avatar
I noticed you don't mention a aftermarket exhaust. I'm sure the stocker is good but if your getting high temps if your flowing through the cat and stock muffler that ain't gonna help much either. Try a straight through muffler, bet that will drop temps a lot
Also may be something wrong with the fooler. E-mail quad he is great at resolving issues.
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: Boost Fooler
