Boost Fooler/smoke Switch?
Old 01-09-2008, 01:19 AM
smoknfords06's Avatar
Question SMOKE Switch WITH EZ AND BOOST FOOLER
Does Anybody Know How The Boost Fooler With Edge Ez Should Be Hooked Up For The Smoke Switch?, Do You Hook Up The Switch To The Boost Fooler Or The Edge Ez?, And Which One Goes To The Map Sensor First The Edge Ez Or Boost Fooler? help Please!!!
Old 01-09-2008, 04:48 PM
Big Smoky's Avatar
I was told to plug the BF in first. If it acts strange, just flip it around. It shouldn't hurt nothing.
Old 01-09-2008, 05:05 PM
06CTDforAU's Avatar
Why do you need the boost fooler with the EZ? It's got built in fooling capabilities according to the boost readings I got with it versus stock when I had mine installed. If both are fooling, you could possible get an overboost code.
Old 01-09-2008, 07:58 PM
I Dont Know Why But It Keeps Throwing A Boost Code Everytime I Turn The Switch On With Just The Ez. Thats Why I Wanted To Know How U Hook Them Up Together, Because I Didnt Think That The Ez Does Boost Fooling? Does Anybody Know For Sure?
Old 01-09-2008, 11:06 PM
06CTDforAU's Avatar
I'm positive the EZ has boost fooling built in. Are you leaving the switch on for a long time? I know if you leave it on for a while it will eventually throw a code.
As for the hookup, I think you are supposed to hook up the fooler and then the pressure box. The smoke switch needs to be tapped to the wires on the EZ in order to work correctly. At least that's how it is on Quadzilla's boxes. I would think it is the same for the EZ too.
Old 01-10-2008, 12:24 AM
Unhappy
i tried it again and it threw a code again, maybe something is wrong with my ez? i didnt plug in with the boost fooler because it says not 2. im not sure wats wrong?
Old 01-10-2008, 12:46 AM
no_6_oh_no's Avatar
Unless there have been drastic changes, the EZ does NOT boost fool. The Juice does but not the EZ.
Old 01-10-2008, 12:52 AM
stock600's Avatar
From what ive always seen from my ez it does little or no B.Fooling. On my truck with just the ez- the addition of the quad b.f. makes a lot of differance. 10-12 lbs boost and pulls lots harder.
Old 01-10-2008, 12:59 AM
stock600's Avatar
But no matter what if it didnt somehow or somewhat alter the map signal it wouldnt hook up to the map sensor. For what its worth the day i ordered my B.F. over a year ago i called edge and asked them that question so as to know wether the quad unit would help me or not. The tech i spoke with said no the ez is our only product that doesnt though?
Old 01-10-2008, 09:27 AM
06CTDforAU's Avatar
Hmmm that's weird. When I had an EZ, I had some boost issues with it (low boost with it hooked up) and when I called, one of the guys in tech support told me that I should be seeing boost in the upper 30 psi range. Thus, I figured it was boost fooling. Maybe it's an '06 thing? Not really sure. Then again, I could have been told a story.
Old 01-11-2008, 12:47 AM
Thumbs up
Thanks Guys I Finally Got It Going, And About Edge Techs They Dont Know Much Everytime I Talked To One They Said Something Different?
Old 01-11-2008, 09:45 AM
06CTDforAU's Avatar
What was wrong?
Killdmycobra
11-12-2010 05:15 PM
Mind If I Smoke
09-13-2007 11:51 AM
Rollin' Smoke
23
06-26-2007 09:04 PM
rockittboy
12-27-2006 09:21 PM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: Boost Fooler/smoke Switch?
